Central Locking help on E30 1990 325i sport
deepb123
Sun Jan 25, 2009 5:21 pm
Hi
Need help trying to resolve my central locking issue.
The drivers lock has been changed at some point and does not lock when I turn the key, it will open. Passenger door locks and opens but no central locking, and fuel cap doesn't lock.
I have to push the lock down manually from the inside to lock the drivers door and when i do this I can hear a motor whir.
Sorry have asked question before but need some guidence to get to the bottom of the problem.
Where should I start?
Any help appreciated.
Sun Jan 25, 2009 5:26 pm
You start with the forum search function, looking for "red AND black", and my username!
The driver's door problem is a seperate issue, and is caused by wear/lack of lubrication of the mechanism, especially the L shaped piece at the rear of the lock barrel assembly.
With the central locking working properly, this problem will be masked.
deepb123
Sun Jan 25, 2009 5:29 pm
Thanks Brian. :D
deepb123
Sun Jan 25, 2009 6:04 pm
Quick question how many red/black wires am i expecting to see 2 or 3?
Sun Jan 25, 2009 6:07 pm
On a saloon, you're locking for two seperate red/black wires, each going to a seperate pin on the car side of the door socket.
deepb123
Sun Jan 25, 2009 6:11 pm
Brian
mines a coupe should i see 3? only asking as I did a search and some people have mentioned a 3rd slightly thinner red/black.
Do I need to disconnect the battery?
Chris36
Mon Jan 26, 2009 2:09 pm
Had lots of issues with mine - Did the red/black wire thing. No joy. It was the central locking ECU. There is a repair guide on here - basically had a broken wire on the resistor. Soldered it together - and coolio...........all working. Dead chuffed.
HartgeH27
Mon Jan 26, 2009 2:17 pm
Chris36 wrote:Had lots of issues with mine - Did the red/black wire thing. No joy. It was the central locking ECU. There is a repair guide on here - basically had a broken wire on the resistor. Soldered it together - and coolio...........all working. Dead chuffed.
Brian will correct me if I am wrong but use caution when resoldering the connection on the central locking control unit as the correct solder must be used or it can cause the unit to blow.
Sat Feb 07, 2009 3:29 pm
Had to fix mine today, using guidance from this thread http://www.e30zone.net/modules.php?name ... =red+black
I had to join three wires together: the red and red/black from the thick loom going to the door multiplug and also the other red/black from the thin loom (of three or so wires). I didn't disconnect the battery (though in theory you should): when you connect the third red wire to the other two, the central locking relay clicks.
Mine had been intermittent for a few months; looking at the green discolouration of the multiplug when the rubber boot was pulled back revealed all I needed to know about the state of the pins within, so I didn't waste time trying to pull the multiplug out!
It was possible to do this with the multiplug left in situ, just removing the speaker for access.
