Guys,
the temp gauge on my m20b20 stays between 1/4 and 1/2. Its had a new rad, waterpump and thermostat. Ive taken it for a 20mile drive but the gauge does not budge from the 3/8 mark. Is this normal??
Temp gauge
scotttollan
hi it could be airlocked try bleeding the system from the thermostat and start it put water in and see if a bubble comes out then rev it then put the screw back in.
hope this helps
hope this helps
bmw 320i e30
- Brianmoooore
Another case of E30 paranoia!! There is absolutely nothing wrong with your cooling system, so leave it alone.
Ignore your mate, he's not familiar with the finer points of BMW design. The whole centre section of the temperature gauge has an expanded scale and only covers a few degrees.
ANYWHERE on the gauge is an acceptable position for the needle, as long as it is clear of the blue and red sections.
Much more important that it doesn't move around, once up to temperature.
