Hi guys
Any advice on a 2.9 built vir Sr20ve 86mm piston... Connecting rods size and any other mods that should be done?
Can i use e36 328i crank (84mm) with 135mm rods with the sr20ve piston?...
Standard Sr20ve setup:
136.3mm conmecting rods
86mm stroke crank
86mm Piston
Advice on 2.9 M20 Build
flybynite
Never heard of using that Nissan piston, I suppose anything can be made to work but it is a lot of trial and error for something that can be guaranteed not to work as well as one of the tried and tested methods.LucianoDfrench wrote: ↑Thu Mar 03, 2022 6:50 pmHi guys
86mm stroke crank
86mm Piston
Why not get the correct Mahle Motorsport piston and make a 2.9 known to work?
Its also a 4 valve per cylinder engine so the piston crown is completely the wrong shape
LucianoDfrench
LucianoDfrench
flybynite wrote: ↑Fri Mar 04, 2022 9:09 amNever heard of using that Nissan piston, I suppose anything can be made to work but it is a lot of trial and error for something that can be guaranteed not to work as well as one of the tried and tested methods.LucianoDfrench wrote: ↑Thu Mar 03, 2022 6:50 pmHi guys
86mm stroke crank
86mm Piston
Makes sense... A friend told me it will work and made about 240hp N/A on the wheels with that setup with 276/284 cam... Maybe ill try the C20XE piston, that's a pretty common 2.9 build but compression sits at 10.0 with that piston... Hoped i could go about 11.0 +
A dished piston that gives 11:1 compression, that cannot be in an M20 build surely!
reggid
There is a lot more to a piston than the bore and CR
E30 325is with M20B31
