89 325i sport resto (work begins at last)
beardymat
Post Sun Feb 03, 2013 6:27 pm
Theyve been up and down, just thought id poke my nose in to see how things are progressing with jbu, also had a look at yours and was stunned to see almost no progress at all, Ha!
Mind you with you currently being locked up/out you should have a bit of time to do a bit. Must catch up.
jimbom30cab
Tech 1 freak
Post Sat Feb 09, 2013 11:11 am
wish mine looked half as good as this
scott180gtb
Post Fri Mar 08, 2013 7:42 pm
Update time.
I have had a busy and stressful time of it the past few weeks. She's is finally back down on the ground minus the exhaust. :cry: :cry:
Its all started to come together nicely with only a few hick ups on the way.
Some pics.
A box of love from Dan. I can't thank Dan enough. Alway's happy to help and take the piss out of the E39 oil burner.
Some more front end action. :D
Nice Plastics.
And back on the ground running with a poorly fitted exhaust.
All that is left to do is sort my poorly fitting exhaust, a miny shake down and a deep clean ready for some mot action!
Its been a hard week with everything conspiring against me.
I had to fit a new thermostat plus a new housing as I bust the old one.
New slave cylinder for the clutch just loads of little shitty fixes but I'm turning the corner.
I need to sort the exhaust before the end of the month ready for a mot for the summer.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Post Fri Mar 08, 2013 9:59 pm
looks really nice that Scott ,there's always set backs though ...oooh the joy's of motoring :)
cobbler2u
Post Tue Mar 12, 2013 6:37 pm
Good to see someone put the effort in to keep a nice car on the road.
Looking good mate
scott180gtb
Post Wed Mar 13, 2013 6:33 pm
Thanks Chaps
Well I insured the slag today ready for some trailer action in the morning.
The exhaust should be fabbed up and fitted tomorrow. All that's left to do is the tracking and then the MOT next week.
This is a view that we should all have out of your living room window. :D :D :D :cool: :cool:
Cars
G-Bear
Post Wed Mar 13, 2013 7:46 pm
Lovely to see nice and refurbed shiney bits going on.. Excellent work..
Post Wed Mar 13, 2013 7:51 pm
Nice work ther Scott.
That does look like it's coming along nicely :cool:
beardymat
Post Thu Mar 14, 2013 8:54 pm
What can i say Scott???????
Truely awesome!!! :cool:
I am so glad you bought JBU as this was always what the car deserved. I am going to have to buy it back one day.
Dezzy
CR24v it's a lifestyle
Post Fri Mar 15, 2013 2:34 pm
Massive epicness there Scott!!!!
Very Very :cool:
The_Diddler
Love it up the more door !
Post Fri Mar 15, 2013 3:23 pm
Not bad Lad......not bad at all :cool:
scott180gtb
Post Fri Mar 15, 2013 3:55 pm
beardymat wrote:What can i say Scott???????
Nearly there Matt :cool:
Here some more pics of the exhaust action. Its not perfect as the front pipes had to cut and the middle silencer is a little far back.
I might save up and just got an oem from the stealers.
Check out the E36 Scubbers!
Thanks for all the comments chaps.
I had a sneaky drive around the estate. The lightened fly and rack make it a different car to drive. :cool:
Plastics back on and MOT Monday. :D
Cars
scott180gtb
Post Sun Apr 07, 2013 8:49 pm
Little Update
I had the exhaust done and was ready for some MOT action but the crap weather made my mind up to try and cure a throttle response problem just of idle.
I posted up a thread in the Tech help section and followed the zone advice to sort any air leaks.
Some pics of the work :D
You can see the small split in the cam cover breather pipe and the O rings on the pipe between the block and inlet manifold had seen better days.
The car was stinking of fuel at idle and sooting up the plugs as per a lot of threads in the Tech section.
After all the work a quick blast up the road under load and a plug checked proved that the donk is not rich when hot.
Lovely Brown Plug :D
I then got busy with the Fertan and some of bilt hammers finest.
I used the S50 gear in all the sills using the lance and gave the inner arches a good blast as well.
I then used the UC stuff under all the kit as a bit of a protective barrier to the elements. I also replaced all of the thin clear protective strips on the Tech II kit as well to stop ant rubbing.
Oh The Shame
One fooked E46 Cab top mount. This went on the way home from the MOT. Should have read the wikki. :x
So today I rebuilt the rear shocks with the spreader washer as per the Wikki.
And some final shots of the MOT and a little Clay bar action.
Only one advisory on the MOT. Well Chuffed.
I had a cheeky drive today before the clean and I can't recommend the lightened fly and rack conversion enough. There is so much more mid range pull when standing on the gas.
I'm also impressed with Gaz gear. I've got the shocks set half way on the adjusters and the ride is nice and compliant but firm enough when pressing on. Time will tell with this set up.
And last but not least. A trailer to pick up the next project. Should have some pictures up this weekend coming. :D :D
Cars
oakey
Post Thu Apr 11, 2013 8:06 pm
The sport looks superb Scott! Very impressive.
Post Thu Apr 11, 2013 8:25 pm
Paedotastic! Is the project E30 based? :eek:
darren_mk
Post Thu Apr 11, 2013 8:31 pm
Lovely car,
Must be very satisfying now its done.
scott180gtb
Post Thu Apr 11, 2013 10:17 pm
oakey wrote:The sport looks superb Scott! Very impressive.
Thanks Dave. Made it home for half four and promtly fell asleep.
Dan I have joined the tech 1 club.
Its a rust free non sunroof version in LHD.
PIC up tomorrow after a clean and strip down!
Cars
scott180gtb
Post Thu Apr 11, 2013 10:19 pm
Cars
scott180gtb
Cars
goosiegander
Zonegoose
Post Thu Apr 11, 2013 10:52 pm
Good choice with the Bilt hamber Scott!
First rate work as always :D
Andy325i
Post Fri Apr 12, 2013 12:00 am
Stunning :)
martywibbs
Post Tue Jul 22, 2014 12:46 am
Where did you get your inner arch repair panels?????
tazi
Post Wed Nov 12, 2014 2:53 am
HI MATE IF YOUR INTERESTED IN SELLING YOUR BMW E30 325I SPORT CALL ME ON 07872558809
Post Sat Nov 15, 2014 11:04 pm
tazi wrote:HI MATE IF YOUR INTERESTED IN SELLING YOUR BMW E30 325I SPORT CALL ME ON 07872558809
Tit !!! this car left the country about a year ago :D
sweep
Post Sat Nov 15, 2014 11:13 pm
Whats best price?
Post Sat Nov 15, 2014 11:56 pm
will you deal with my agent ?
beardymat
Post Wed Jul 29, 2020 9:12 pm
Nice to see the old thread still here. I think I need to do something about the missing photos though!
