edit must be an e34 one, this donk is out of a 5er
M52 b30 stroker rebuild back on the road
your doing good here m8
+ a yard full of scrap turds
magpie wrote:
erm,wtf is this?
This is a heater which plugs into the M50 air box. Throw it away. The hoses connect to the bottom of the throttle body and they can be removed. Have a look at the "M50 manifold onto M52" thread mate for pics of my inlet manifold and the plumbing going to the throttle body mate
and this![]()
Connector for lambda sensor mate, I'd guess that engine was not running a lambda sensor, so won't have been running right (unless there is a lambda sensor in the exhaust manifold) - I would recommend you sort one mate. Speak to Steve (E30topless) as his was running without one and was gash until he sorted it.
what's the part on the left?
I think that is for the exhaust flap solenoid or to do with carbon canister crap, not needed as far as I know
Dan you homo
- Homo Hair
Looks like some crude as hell resistor.. The fan setup seems errrm. Interesting. I'd chuck the wiring away and start again.
- Homo Hair
E30BeemerLad wrote:Dan you homo
i'll see if it works and if not i'll see yoda for one of his
Mick, Dezzy has a non-vanos DanThe loom for sale (engine loom)
Otherwise speak with Yoda about a fan loom
Here is the pics etc for how the plumbing should be on the throttle body
http://www.e30zone.net/modules.php?name ... 12#1990612
Nasty!
This regulates coolant to heat the throttle body, fook it off son.
Make sure you fit a lambda in this!
You can chop it out, just make sure you insulate the Red/White wire if you dont remove all of it
cheers Dan
the car has no lambda?
is this what Dezzy done for topless steve?
that link will come in very handy Lee
Dezzy
- CR24v it's a lifestyle
Fook me, magpie you are bless!
How's things Dan?
I was going to reply but couldn't be arsed with sifting through the pics etc.
How's things Dan?
can you sort this lambda jobby out Dezz,i know steves ran loads better after you'd sorted itDezzy wrote:Fook me, magpie you are bless!
How's things Dan?
Dezzy
Yeh of course mate. You will need to get one though. E34 M50 lambdas are a better length.
Cook318IS
i have a near as new bosch lambda from when i had my m50 in my e30
i think i only did something like 500 miles on it
so i buy a new one for e34?
or look at ebay one?? is the loom a separate part ???
looks like i have a list developing!
I've got one here mick you can have for nowt, only problem is the wiring has been bodged with terminal block, nothing 10 mins with a soldering iron wouldn't fix though.
your a star mateE30BeemerLad wrote:I've got one here mick you can have for nowt, only problem is the wiring has been bodged with terminal block, nothing 10 mins with a soldering iron wouldn't fix though.
pm on way Dude
Dezzy
I have one here Mick with no bodgy wiring mate from mine. I you can have that when we weld the boss in and fit it. The pic you posted with the plug in the clip at the bottom of the block (inlet side) is where it plugs in.
I will start a list here of the bits you want off me
ok dez don't forget the p/s pipes i need
lee cancel that last pm m8,looks like wor dezza has the goods
aye champ
leeparkes
I dont think its a lightened flywheel Mick, the guy who originally done the conversion did a bit of sump shaving to make it fit.
http://www.e30zone.net/modules.php?name ... sc&start=0
Did you pm him?
Oh and, What is this?
Did you pm him?
leeparkes wrote:I dont think its a lightened flywheel Mick, the guy who originally done the conversion did a bit of sump shaving to make it fit.
Did you pm him?
Jhonno wrote: Looks like some crude as hell resistor.. The fan setup seems errrm. Interesting. I'd chuck the wiring away and start again.
just noticed this post,thanks for the offer m8.Cook318IS wrote:i have a near as new bosch lambda from when i had my m50 in my e30i think i only did something like 500 miles on it
i'll get the one from Dezzy as he has a few bits i need.
leeparkes
Yes but what is 'meant' to be on the end of that plug?
I agree with jhonno on the fan wiring, start from scratch bud
did the fan kick in when you had it?
leeparkes
I didnt trust the relays so i hot wired it to a switch.
Dezzy
No problem mate.
P steering pipes
Lambda boss and sensor and a bit of welding.
Out else you need?
P steering pipes
Out else you need?
poss loom none vanos,does it have the leccy fan set up? i have a 3 pin sensor on the right of the rad.
Dezzy
I have a loom and ecu here mate but the fan loom is a seperate loom. Danthe will make you one and it will be twin spead. Perfect plug a nd play option. just give him a pm
will do m8,Dezzy wrote:I have a loom and ecu here mate but the fan loom is a seperate loom. Danthe will make you one and it will be twin spead. Perfect plug a nd play option. just give him a pm
what part of the zaust shall i fetch over to you for the lambda job?
not sure if the rear fanimould needs further fettling for the e36 rack yet though
Your better off getting it on the car before fitting the lambda TBH
Dezzy
As yoda says get it in an running and drop down in the car mate. We will place it and have a look from there
sounds good to me,i'll be down soon for the pipes and a l@@k your fan loom and ask a shit load of questions
Dezzy
magpie wrote:sounds good to me,i'll be down soon m8 for the pipes and a l@@k your fan loom and ask a shit load of questions
Sound thats fine by me mate
wess
magpie i have pm'ed you about that loom i got of danthe
what diff is best to use for say 135mph ish and good m/way mpg in 5th?
i had a zoner round mine yesterday with am m52 and 3.46 diff and he limits out @ 125mph.
so the 3.64 i have will be no good to me
