M52 b30 stroker rebuild back on the road
Post Sat Aug 23, 2014 11:23 am
rich318i wrote:asbestosis included ?
no the asbestos was left at the place i got the garage from ,i used to strip assy for a living and the old UNCRACKED roof sections were not dangerous although the correct safety gear was worn anyway.
now kindly stop posting on my thread ...OK troll :roll:
Post Sat Oct 25, 2014 1:00 am
now the new home is nearly complete [ asbestosis free ] some updates are possible ... wheels in motion and all that 8)
i'll sorn it when the gritters appear .
here we go again, taking a good running engine out that nailed a 14,2 at pod this year fully loaded with camping gear, spare wheel,sub etc you get the idea :mad:
m52 3.0L 6-speed for next year and i think i'll be happy and the car will be where it's at and all that ..
it's REAL 8O
rich318i
Post Sat Oct 25, 2014 1:04 am
dont put a tumble dryer in it will ya. really hope thats the cam thats off centre.
three little pigs spring to mind
Post Sat Oct 25, 2014 1:11 am
rich318i wrote:dont put a tumble dryer in it will ya. really hope thats the cam thats off centre.
ha ha ..you are a pathetic joke .
trolling my build thread again :roll:
let's see some pics of your car..my monies are on you have every right to be jealous :wink:
rich318i
Post Sat Oct 25, 2014 1:22 am
im so jel its off the this world
craigieeb
Post Sat Oct 25, 2014 2:02 am
magpie wrote:
Please no!
Not the wow factor spec 500
Post Sun Nov 02, 2014 12:34 am
3.2 evo e36 6-speed v's e36 328i 5-speed ...nice to have a choice .
rich318i
Post Sun Nov 02, 2014 12:45 am
go for the 6 speed they are great with a good 3.9 diff :D
Post Sun Nov 02, 2014 1:02 am
rich318i wrote:go for the 6 speed they are great with a good quiet diff :D
rich318i
Post Sun Nov 02, 2014 1:11 am
I got a SR-17 diff for sale signed by roger noble and walter cable
jimbom30cab
Tech 1 freak
Post Sun Nov 02, 2014 9:28 am
6 speed goodness. Result :)
Thus should be good.
When are you fitting it Mick?
Post Sun Nov 02, 2014 11:17 am
jimbom30cab wrote:6 speed goodness. Result :)
fitting it when the m52 stroker is built jim .
Post Fri Dec 05, 2014 9:36 pm
i see my troll is in the jail house so it should be safe to post tonight :D
bit of an update , i've got the spare m52 in the garage and mounted up on the shiny new engine stand ...also managed to get the crank nut undone on the m54b30 block so i can now rob it's internals ..... took the block to a local garage who's big windy gun made light work of the crank nut ..... free of charge :D
list of needed parts are
valve stem oil seals [ got ] elring
both crank seals [ got ] elring
head bolts [ got ] ecp
con rod bolts [ got ] BMW dealer
head gasket [ got ] GSF premium
may not need these parts but i'm going to look at prices anyway just in case...
main bearings
big end bearings
piston rings
the plan is to install the b30 crank/cons/pistons providing the bores don't need a re-hone on the m52 block and check clearances to see if i need to buy the other parts .
if anyone can see owt i've missed or offer some HELPFUL advice feel free to chip in ....
Rich318i need not apply :mrgreen:
why do some people use an m54 cam , it's only one of them and i've forgotten which side :mad:
325ftmfw
Post Sat Dec 06, 2014 12:17 am
cute garage.
Post Wed Dec 10, 2014 6:21 pm
small update ...the m54 block has been pillaged and my bullseye hid's are ready to fit :D
spare m52 project b30 engine with m54 internals ready and waiting
m54 block and other m54 parts scrap pile
changing my smoked smiley's with these bullseye ones and HID kit ... much prefer this look .
sidelight led's ...i'll probably only have them plugged in for the mot as i just want the projected main light illuminated and the side lights will spoil the look i'm after . i just ordered some of these 130w intense white bulbs for the high beams ......blinding :wink:
http://www.ebay.co.uk/itm/141167243546? ... EBIDX%3AIT
next purchase is a chair for the garage winkeye
Post Wed Dec 10, 2014 7:22 pm
magpie wrote:. i just ordered some of these 130w intense white bulbs for the high beams ......blinding :wink:
You'll need to change fuses 1 and 2 to 15A, and replace the wires from these fuses to the headlamps and the earth wires from the lights to the inner wing with at least 1.5mm2 wire, and preferably 2.5mm2.
MattTheHat325
Post Wed Dec 10, 2014 7:59 pm
Good stuff mick! Hoping to get the m52 out of my touring into my e30 in the new year, heavily considering the 3.0 option. Are you planning to do anything at all with the top half?
87mtech27
Post Wed Dec 10, 2014 8:14 pm
magpie wrote:small update ...the m54 block has been pillaged and my bullseye hid's are ready to fit :D
Love the old skool gas heater :cool:
Initial glance at the picture it looked like you broke the con-rods :mad:
Post Wed Dec 10, 2014 8:24 pm
i numbered them but didn't need to :mad:
got that heater free off gumtree :D
Post Wed Dec 10, 2014 8:26 pm
thanks for the warning 8)
Post Wed Dec 10, 2014 8:28 pm
MattTheHat325 wrote:Good stuff mick! Hoping to get the m52 out of my touring into my e30 in the new year, heavily considering the 3.0 option. Are you planning to do anything at all with the top half?
an m54 inlet cam and that's it for now ,already got a bbtb and m50 inlet with refurbished m52 injectors .
MattTheHat325
Post Wed Dec 10, 2014 8:48 pm
Spot on, you will probably be on your next engine conversion by the time mines done!
Post Wed Dec 10, 2014 9:10 pm
MattTheHat325 wrote:Spot on, you will probably be on your next engine conversion by the time mines done!
ha ha who knows :mad:
Post Sat Dec 20, 2014 9:56 pm
had my good man Craig drop round to strip and inspect the spare m52 which we are both now not so sure this was a good running engine going by all the blocked water channels.
i doubt this would of lasted a week in it's current state ...
not the end of the world though it just needs a good clean out , all the head bolts came out ok with no stripped threads so hopefully it'll go back together the same .
i found an engine rebuild place not far from me who will be putting the m54 crank back in the block using Karl Schmidt mains,big ends and rings for £225 inc vat for parts + his labour which won't that much . it looks like the block is getting a re-hone just too keep things sweet .
Craig took the cylinder head home to do the valve stem oil seals and i'll be dropping the block and other parts off on Monday .
the only thing getting in the way is Christmas :D
appletree
Post Sat Dec 20, 2014 10:18 pm
When do you plan to have it done by? When the weather picks up?
Post Tue Jan 20, 2015 5:03 pm
craigieeb
Post Tue Jan 20, 2015 5:22 pm
It's back! :D
Post Sat Jan 24, 2015 10:31 am
got the engine block back earlier this month fully built up and re-honed with KolBen schmidt big ends, main bearings , piston rings .
ECP elring and febi crank seals also new BMW con-rod bolts .
freshhh!
Honed in ....
sat looking pretty waiting for the cylinder head to arrive .... howay man Craigeeb pull ya finger out :teehee:
after a strategically placed rocket had been lit ....Craig turned up bearing gifts ...well not really , just my cylinder head with all the valve stem oil seals replaced :D
two hours later and all the worry is over , it's finished as far as i can go until i pull my healthy m52 out and strip it of the other parts i need such as sump, loom manifolds etc , i've stuck an old e36 sump on for now , the cams were drizzled with oil before the engine was turned a couple of full revolutions .
new sump gasket,oil pic up and the coolant stub on back of block gaskets + e36 evo spigot bearing and oil filter waiting for me .
next step is get my engine out of the e30 and have the engine bay painted, i've managed to get some new replacement engine bay stickers from Puka on here for the finishing touches .
never ending story :D
Cypriotgeeza
Post Sat Jan 24, 2015 9:29 pm
magpie wrote: never ending story :D
It always is! Theres always SOMETHING to be done on an E30! :mad:
Prob what makes us keep them so long as if you feel like you've actually finished it you might move onto another car! :(
Good progress Mick! :thumb:
Ps i love this! 8) >>>
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
Post Sat Jan 24, 2015 10:35 pm
doubt i could have the same patience with another car , i do like working on it and learning stuff along the way .
cool looking cars :D
bigredbmw
Zone Supporter
Post Thu Jan 29, 2015 9:37 am
looking good m8 i will have to pop over
Post Sat Feb 07, 2015 10:24 pm
i'm thinking of running a new zaust and this one looks ok
http://www.ebay.co.uk/itm/270704893083? ... EBIDX%3AIT
but i'm considering having a custom s/s one 2 and a half inch single bore with same sized twin exits as the scorpion ...i want some kind of refined noise over the scorpion if ya get me
jimbom30cab
Tech 1 freak
Post Sat Feb 07, 2015 11:01 pm
If you can find a used BTB for sale it will blow your mind away. It honestly sounds like standing next to a world war 2 spitfire. Small kids run away crying, old people have involuntary bowel movements and people shelter undertables thinking there is an earth quote. They are absolutely flipping epic.
Post Sun Feb 08, 2015 11:02 am
i sold a good looking twin exit s/s back box i bought off sweep to eko on here for his mugello turd that i never fitted or heard it's soundtrack so to speak ...anyhoo the said back box is currently wedged up pacers back passage still fitted to the mugello rot-ter so there is hope i might get it back and he might get the spanners out and frag it lol .....
