I have a new pc tower and have bought two different external cd drives so I can rip music to the pc.
Both start to rip and after @ two cd`s an error message comes up .
Any ideas what I`m not doing correctly ?
Cheers Mart.
A little bit of help ??
BenHar
Well, some idea of what the error message says might help.
Ben
Ben
BenHar
I would google for problems with the software you are using to copy from the CD players.
Ben
Ben
Satan
Remove the CD from the external case and fit it internally, could be lack of power vis the USB port, sub standard USB cable (you Northerners like to do stuff on the cheap) ;o))))))
Oh and lower the speed that you are ripping at.
I went direct to the pc and it was a bit better but I will lower it right down, what do you suggest ?
Windows 10, like I have always said, if you dont know then you dont know !
Streettech
