Delocking an E30
Andy325i
Post Mon May 23, 2005 12:02 am
Does anyone know if it is possible to delock an E30 and keep the deadlocks working?
Any ideas greatfully received
Andy
bootyman
Post Mon May 23, 2005 8:30 am
The only way i can see it working is by de-locking it and using you alarm to operate the central locking. You'll just have to make sure you dont get a flat battery or you'll be in trouble :lol:
Karan
Post Mon May 23, 2005 8:39 am
i have this on mine and it looks sweet and works fine.....
i still have stock lock on boot and my battery is in the boot so its no big deal..... only prob is if ure central locking packs in..... 8O
Borderbmw
As far as i know you wont be able to deadlock with remote locking as you cant activate the second action,but possibly if you could link a second channel to the locking you may be able,but as bootyman says if you get a flat battery and its deadlocked ............... :cry:
320Touring
Post Mon May 23, 2005 9:42 am
could you not replace the central locking with a solenoid system (thus totally removing the troublesome control unit and locks?!)
I know there are several solenoid kits available for VW beetles and golfs, could prob be altered to suit...
what Karan says is a good idea-keeping the lock on teh boot so you can get to the battery :wink:
failing that just filler the locks :lol: :lol:
Andy325i
Post Mon May 23, 2005 10:10 am
Karan wrote:i have this on mine and it looks sweet and works fine.....
Good idea, but I have found an odd one lol A mate I know with a totally standard 325i, doesn't use it that much at all, so battery is always flat on it. When you try to open the boot with the key you cant (it just won't turn)
Open the doors with the key no problem and apply power to the +ve connector under the bonnet, wait a few secs and then you can operate the boot lock as normal. Strange or how they all are?
placey
Post Mon May 23, 2005 5:49 pm
andy
i've de-locked mine and asked the very same question about deadlocks of many people as i wanted to keep them. using a solenoid is a viable option - so is using a capacitor to trigger the deadlocks a second or two after the main locks are activated.
i decided against acticating deadlocks in case of flat battery problems, especially as my battery is under the bonnet and not in the boot. the fact that the doors no longer have lock barrels accesible makes it harder for theives to gain unforced entry - in theory at least.
you may decide to rig up some method for entry should your alrm fob or battery power fail - suggestions might include practising slim jim entry technique (not very difficult to master, depressingly) or perhaps rigging a hidden bonnet/boot release cable under the car so that only you know where it is. it's also worth considering adding an alternate battery charge point - easy if you have a bit of an install already.
in terms of security i'm a big believer in the physical deterrent - buying a disklok and useing it every time you leave the car without fail not only makes the car significantly more difficult to steal it will also put off any chancer sufficiently to move onto the next car which is an easier target.
even deadlocks don't prevent the dreaded brick through the window technique, but disklok might just prevent it happening.
paul
i saw a doctor and she gave me some pills....
Andy325i
Post Mon May 23, 2005 5:57 pm
Some good stuff there Paul :)
Have thought about the disc locks, 2 mates have them, very good.
How much are they now?
Does anyone have any good advice on trackers etc? prices?
smit325is
Post Mon May 23, 2005 6:14 pm
I have de-locked my and its grand got a clifford fitted and if the battery goes flat just open the boot with the key and jump it. looks very well to .
placey
Post Tue May 24, 2005 11:22 am
andy
i think that the disklok has gone up to Ԛ£80 now from halfrauds.
i've thought about trackers but the annual fee is too much for me, running cars and bikes is too expensive already without adding more subscriptions.
what appeals to me is a card system (pioneered by mercedes??) whereby the car is immobilised unless the card is within a certain distance of the sensor. this would make theft difficult if you're not about and car-jackers would find that the car cuts out on them once they're 50 yards or so down the road.... i beieve that some alarm companies offer this now.
if i had this fitted it still use the disklok though.
an alternative to the disklok is the removable steering wheel. daryl(zim) has one in his (stunning) m3. it comes off in a second and is less cumbersome than the disklok. it cannot be used for factory steering wheels however which puts me off.
paul
Brenner5
Post Fri Jun 24, 2005 10:36 pm
placey wrote:andy
paul
can you explain more about this please??
how would the capacitor activate thedeadlocks and what type of equipment will be needed to do this..
i am thinking of de-locking mine but want the deadlocks enabled ..
320_Fizz_i
stevo
Post Fri Jun 24, 2005 11:14 pm
i heard tip for de-locking, for under bonnet battery's run 2 wires from the battery to the front bumper, tucked up inside so that if the battery goes flat you can connect another one up and give it enough power to unlock it
Brenner5
Post Fri Jun 24, 2005 11:21 pm
stevo wrote:i heard tip for de-locking, for under bonnet battery's run 2 wires from the battery to the front bumper, tucked up inside so that if the battery goes flat you can connect another one up and give it enough power to unlock it
thas a good idea esp if the boot lock messes up on you too because mine has the batteryin the back (like all 325i's) so a wire underneath the back bumper would be ok as back up :D
good thinking :cool:
320_Fizz_i
mrLEE30
Post Sat Jun 25, 2005 5:36 am
Flat battery should not be a problem as it is easy to open the bonnet with a screwdriver through front grille. Even if battery in the back the main power (+) lead will run through to somewhere near the fuse box, so can get jump leads on this. PM if anyone wants to know how to open bonnet, first time E30 users need not apply! minimum 150 posts!
mrlee
placey
Post Sat Jun 25, 2005 6:33 pm
brenner
unfortunately i don't know enough about e30 electrics to explain a great deal more...
i know that the lock electrics are tucked down below the speaker aperture in the front footwells. also that the passengers side door is deadlocked via the drivers side key barrel - hence this must be an electric signal trigger. if i'd decided to go this route i'd have placed a meter on various wires and looked for a pulse when the deadlocks were activated, hence i'd know which wire triggered them. i'd have then gone through my local bmw dealers and obtained a drivers door deadlock trigger mechanism from a left hand drive car and fitted it to the drivers door. a suitable capacitor could then be fitted to the central locking trigger wire to activate the deadlocks after a short delay - say about 1 second.
i'd need a functional car to experiment on that wouldn't mind a bit of damage/repair to it's wiring loom, i could then figure it out. i didn't want to damage the loom in mine - it's too good!
helpful?
paul
BrAdZ
Post Sat Jun 25, 2005 7:33 pm
mine is being de-locked, I have just had an alarm that has an orange simcard on it and it will ring me iff the alarm is triggerd,I decided not to bother with the deadlocks, As i have a cab so they could easly just cut through the roof, so a deadlock wont really help,
But i dont really tend to leave the car in places that are not secure, its parked in the garage 5 days a week, and when i do park it somewhere i make sure its secure,
Also dont leave thinks on display...... Take them with you or deadlock them in the boot, and dont leave your Wheel key in the glovebox like everyone does and the Facia off your headunit under the seat! :roll:
Brenner5
Post Sat Jun 25, 2005 9:12 pm
placey wrote:brenner
helpful?
paul
seems like a bit of a job :(
i am only really interested in deadlocking the boot as thats where my install will be..
if i delock the car, the deadlocks won't work and the boot could be opened.
but once the boot is closed it won't matter if it is deadlocked or not as it is very hard to break into it ???
320_Fizz_i
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 9:14 pm
i used to have a deadlock bolt fitted in an e30 near the end of the bootlid that locked into the rear wing Daz
www.oldskoolfantasy.co.uk
Brenner5
Post Sat Jun 25, 2005 9:17 pm
dazleeds wrote:i used to have a deadlock bolt fitted in an e30 near the end of the bootlid that locked into the rear wing Daz
how did that work?
bolted in the rear wing?
did that mean that you used the key to deadlock the bootlid and then put the alarm on?
please elaborate..
320_Fizz_i
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 9:21 pm
where the i badge is on your boot and the same place on other end each side had a mini barrell with a long multilok type key when you locked them they went inside the rear qtr panels
so you had everything else on remote and the boot with remote and the 2 manual locks
very secure as had big sounds back then Daz
Brenner5
Post Sat Jun 25, 2005 9:26 pm
dazleeds wrote:where the i badge is on your boot and the same place on other end each side had a mini barrell with a long multilok type key when you locked them they went inside the rear qtr panels
i am doing the extra security for my install :)
you got any pics ??
where can i get the locks from??
sounds like a good idea but i don't think it will look that nice from the back :(
320_Fizz_i
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 9:32 pm
this was about 10years ago mate so no pics sadly and dnt know how much they would cost but they shouldnt be too much
yes they are noticeable on the boot but you can get some very small barrell type locks and with black keyhole covers they wouldnt stand out on your car i wouldnt think
heres a thort for ya put them in the top of the bootlid and hide them in the spoiler somehow??
reckon best place to find em would be a home security type shop Daz
Brenner5
Post Sat Jun 25, 2005 9:35 pm
dazleeds wrote:this was about 10years ago mate so no pics sadly and dnt know how much they would cost but they shouldnt be too much
thanks for the idea mate
i will definetly be doing something to secure the boot..
will post up whatever i do :D
320_Fizz_i
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 9:38 pm
nice one mate
i like the idea of hiding em in the ends of the spoiler and it would be so easy as well if done there good luck mate
placey
Post Sun Jun 26, 2005 9:34 pm
brenner
the good news for you is that the boot deadlock is operable from the boot key barrel. once you've de-locked your doors the boot can be independently deadlocked using the door key in the boot lock. i keep my boot deadlocked always.
paul
Brenner5
Post Sun Jun 26, 2005 9:49 pm
yeah, i was checking the boot today and realised that it is separate from the rest of the doors.. which is good news :D :D
320_Fizz_i
