What filter is best?
Giggz
Post Sat May 21, 2005 1:21 pm
Can anyone advise me on what is better...a K+N Panel filter or cone filter for my 325i?
jmc330i
Post Sat May 21, 2005 1:36 pm
Most will tell you to stick with the original airbox and replace the panel filter. Cone filters are ok, but need a heat shield to cover them, the cold air feed pipe supplied with most cone filter kits just wont cut it.
If your after induction noise, you can always drill the bottom of the airbox. The cone filters Ive heard on 4cyl cars (205gti, astra gsi) have been all rasp and no roar :(
James
'91 325i Sport
'93 318i touring 16v
Giggz
Post Sat May 21, 2005 1:50 pm
Thanks for that. I will go for the panel filter then. Just out of curiosity...would i have to get a makeshift heat shield or can i obtain them from somewhere?
jmc330i
Post Sat May 21, 2005 2:00 pm
It would have to be a custom heatshield. I dont think anyone sells them, but I could be wrong.
BMC do their Carbon Dynamic Airbox, its a bit pricey but its meant to to be good. Check out the group buy section.
James
'91 325i Sport
A1BMW325iSport
Post Sat May 21, 2005 2:20 pm
i have also heard that the bmw airbox is pretty good,
it does cost a bit as mentioned by jmc330i, i opted for
the K&N panel filter, it works pretty well and there is more
noise from the induction now :)
