how many miles?
tim_s
Sat Dec 22, 2007 11:41 am
How many miles do you guys do in your e30? I've done nearly 1,000 miles in the last wk without her missing a beat, and do about 20k a year. I'm considering a 328/330 e46 coupe to replace the e30 at the moment on the grounds that mine's too much of a focused sports car and not ideally suited to doing all these miles (quite noisy, not exactly luxurious etc), but am unsure of whether it will end up costing a load more money to run, whether it will actually be any more reliable etc, and i'll clearly miss the way the IS looks and performs. Was pretty uninspired by a 330 coupe I drove last wk in terms of straight line performance, but the chassis seemed very good.
Here's a nice pic of the IS all dirty when i stopped for gas last night (£10 for 130 miles :D):
and a few weeks ago at beemer redeemer:
So come on then, who does more than 20k a year in their e30?
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
Cotty
Hartge Crew
Sat Dec 22, 2007 11:44 am
Er no I only did 3,276miles this year and that includes an 800 mile trip to Le Mans
I catch the train to work and only use my car weekends thats why it only has 73,00 miles on the clock
tim_s
Sat Dec 22, 2007 11:48 am
nice! that's well impressive. mine had 70k on the clock when i bought it (2002) :( now at 140k. engine's only done 24k though, and cyl head about 5k.
Sat Dec 22, 2007 12:14 pm
I did about 30k in the first 12 months of it being M50 converted, ive done 18k since July 8O
Engine is now around the 240k mark and the chain has started to rattle. I hope I get an engine put together soon :!:
Demlotcrew
Sat Dec 22, 2007 12:17 pm
Id like to do 2k in mines :eek:
Sat Dec 22, 2007 12:19 pm
You must like that polo turd Andrew :lol:
lowey
About 4,000 miles a year, a lot easier to keep clean :cool:
oakey
Sat Dec 22, 2007 12:26 pm
I drive mine almost constantly everyday :D About 10k a year and In 5years the only 'proper' let down Ive had is the prop falling out 8O
darkchild
Sat Dec 22, 2007 12:49 pm
About 4-5K in the E30.
The E36 is my daily work turd. Most I've done in a year in that is 30K. No way would I do 30K per annum in an E30!
Demlotcrew
Sat Dec 22, 2007 12:52 pm
DanThe wrote:You must like that polo turd Andrew :lol:
No i just like to improve on the 'H23' got a cylinder head to do over the xmas breaks winkeye
full port to 30mm, flow benched and matched, Race valves, springs, MS top hats, and some very very very mild cams (for testing only)
alex-e30
Sat Dec 22, 2007 12:56 pm
well my speedo stopped working a good while ago but i put in around £60 a week :cry:
this is my beemer, there are many like it but this ones mine
(OO=[][]=OO)
Sat Dec 22, 2007 12:59 pm
darkchild wrote:No way would I do 30K per annum in an E30!
Why not? Cant think of a car I would rather have as a daily driver :?
darkchild
Sat Dec 22, 2007 1:02 pm
Nothing against the E30 but mainly because I'm too tall and the top of my head is indented in the sunroof! Crap "un-comfort" seats too! It will stay as a weekend toy. :D
jonboye30
Sat Dec 22, 2007 1:09 pm
had my IS since may, i use it as my daily runner and clocked up 16k and it has never skiped a beat!!
tim_s
Sat Dec 22, 2007 1:19 pm
lol you sound like me (with the very very very mild cams!). must admit my mild cams are a bit of a disappointment - I mean I'm chuffed it still pulls like a train (I've gained throughout the rev range, tested on the rollers) and idles like factory, but hasn't exactly done as much as i'd like for the performance. A stronger inlet cam will go in mine if i hang on to it, would like to get 200bhp on the standard inlet manifold etc with perfect daily driving behaviour. It will still then have cams less wild than some factory s14s, and with smaller valve size/squarer engine so it should still pull nicely. What does the 30mm refer to when you say port to 30mm? you got a 2.5l block now? Any thrreads anywhere about your engine? Would like to see what you've been upto!
DanThe, that's some serious mileage :O You on LPG yet?
Demlotcrew
Sat Dec 22, 2007 1:25 pm
Tim ive got three engines on the go right now;
A MS 2.5 ~ 330bhp
A MS 2.0l long rod ~ 260-290bhp
A Stock short block but uprated Top end 2.3 for road use (shim under, lighter valves, top hats etc) ~ 240bhp
No threads mate, dont see anyone being interested in this on the Zone.
30mm is where each inlet port is 30mm in diameter
Andrew
Sat Dec 22, 2007 2:34 pm
Me as well!! The E30 seats (both types - I drive E30s with both) are the most comfortable car seats I've ever ridden in. I've done six hour non stop driving stints (another advantage of LPG) and got out of the car as fresh as I got in.
The only other BMW I get to ride in or drive regularly is an '06 535D, and I wouldn't swap that for an E30. I don't find it any more comfortable, and it's utterly soul less.
Jesus325iTouring
Frog freak !
Frog freak !
Sat Dec 22, 2007 3:41 pm
We were doing around 25k per year,but since having the R5 I now do about 15k in that instead.
The Tourings done 239k of which over 85k are "our" miles.Splendid :D
gazza
Sat Dec 22, 2007 3:49 pm
Demlotcrew wrote:Id like to do 2k in mines :eek:
when its not running out of petrol :wink:
Sat Dec 22, 2007 4:10 pm
Demlotcrew wrote:Tim ive got three engines on the go right now;
A MS 2.5 ~ 330bhp
Are you serious?!
Sat Dec 22, 2007 4:21 pm
Ive done 14k since i bought the car in july 06 and the only thing to go wrong was the clutch master and slave cylinders, the rest has been maintenence or upgrades.
tim_s, i had a 330ci convertible at the same time as this and one had to go because of my first child. I chose to keep the E30 as 330's are ten appeny, will depreciate, and i wasn't overwhelmed with it tbh. My E30 was the opposite of this. Yes the E46 was nice but didn't excite me or make sense economicly.
BMracing
Sat Dec 22, 2007 4:40 pm
A MS 2.5 ~ 330bhp
Are you serious?!
x2!!!
I used to have a daily 70 mile round trip to work, as well as a fair bit of 'leisurely' driving. I bought our 4 door with 89k on it and within 3 months it had 96k. :? I find it very comfortable and quiet on the motorway, even with the mongoose exhaust that went on not long after i got it, although it was on the standard suspension at the time.
In my current job i have an 8 mile round trip to work, so i'm keeping the mileage down on the tech 1 (although i'm using the 4 door again at the mo), but the fuel consumption is horrific as its always running cold. Still I have more petrol money these days to have fun at the weekend. :D
Max
Sat Dec 22, 2007 10:33 pm
tim_s wrote: DanThe, that's some serious mileage :O You on LPG yet?
No, im saving the kit I have for an E34 525i touring, my E30 is overweight enough as it is and I think a gas tank behind the back wheels would just kill the fun factor.
Once I have a 5 touring up and running on gas the E30 will take a bit of a back seat as the kids are getting bigger and rear leg room is non forgiving.
I may gas it and give it the mrs or I may sell it, either way I wont be driving it very often... :(
d6dph
Sat Dec 22, 2007 10:43 pm
I done less than 4k last year. I have a company wagon for daily abuse so no need to drive the turd. :)
pnd
Sun Dec 23, 2007 11:58 am
Nothing against the E30 but mainly because I'm too tall and the top of my head is indented in the sunroof! Crap "un-comfort" seats too! It will stay as a weekend toy. :D[/quote]
hOW TALL ARE YOU? I AM 6"5 and have no issues with roof height or leg length in an e30 unlike a lot of other cars which is one of the reasons I have stuck with them. As for mileage i do 10k per annum and agree the e30 is perfect for a daily driver except for fuel consumption and the regularity of little niggles that need sorting as for reliability though they really are very good if properly maintained.
darkchild
Sun Dec 23, 2007 5:14 pm
Brianmoooore wrote:Me as well!! The E30 seats (both types - I drive E30s with both) are the most comfortable car seats I've ever ridden in. I've done six hour non stop driving stints (another advantage of LPG) and got out of the car as fresh as I got in.
Whilst an E30 is a great car and has numerous plus points its refinement is nowhere near an E34 nevermind a 5 Series two generations later. Even an E36 is in a different ball park in terms of comfort. The appeal of the E30 (for me anyway) is in its rawness and the way it connects with the driver. Comfort seat are crap though, period!
P.S. I'm happy to swap the E60 for my E30 :wink:
Moz
Sun Dec 23, 2007 5:20 pm
I do anout 22k a year, on my m40 1.8 AUTO (haha) returns 30mpg consistent motorway, sports seats in leather are more comfortable than the wifes E46 sport seats with electric lumbar support. No real issues just regualr oil changes and services and just now am replacing the elcetric heater valve.
Long live the E30's.
Moz
tomze30
Mon Dec 24, 2007 3:36 pm
I switch between the iS and the cab, approx 6 months each in a year. Total mileage about 4000. Then I'm lucky, I don't have to drive to work :D
E30Dale
Mon Dec 24, 2007 8:45 pm
i have had my 318IS on the road since May this year and have done 16k since then
i put £30 in the tank and get 230miles :)
comfort wise the sport seats i find very comfortable and they keep you in place when goin around corners 8)
M-Tech 2
Lazur Blue 318iS
Simon
Mon Dec 24, 2007 8:53 pm
I did nearly 3000 miles over the last year in the E30 touring, and so far have only done 2000 in the E36 touring since buying it in March.
The H27 hasn't turned a wheel since my ownership yet.
ShepsEvo3
Master of go faster
Thu Dec 27, 2007 1:22 am
My Evo2, no miles as its STILL in the bodyshop getting restored.
Black SE done just 30 miles this year.... to work and back once!
The white 325i touring... about 2k this year,
The 318is I have just bought, already done nearly 500 miles in the week I've owned it... love that car lol.
The other E30's aint turned a wheel this year andmy daily driver (205GRD) I have done about 10K this year.
Wondering why I still have the Black SE as I dont use it anymore :cry:
www.sabre-tuning.co.uk
tailoutcharlie
Thu Dec 27, 2007 1:55 am
i find the e30 sports seats the most cmfortable ive ever used.
i do about 20miles each way to work in the 325 and it hasnt let me down yet, even frozen solid it starts right away.
if i drive like a saint (ie 70mph) on the motorway it does 30m/g happily.
GOD I LOVE E30 BUILD QUALITY 8)
Chris
BadDave
Thu Dec 27, 2007 10:35 am
I used to do around 500-600 miles a week in the old 325 tourer when using it as a daily driver
I now have a company van so it sits at home most of the time and only comes out at weekends and the occasional evening
Now £100-£120 better off each week as the company pays for my fuel bill now
So that's more disposable income to spend on the "Old barge"
:lol:
TRANSPORTER
Fri Dec 28, 2007 1:34 pm
WOOOOOWWWWWW 130 miles on a tenners worth of fuel, how do you manage that,even if I drive like miss daisy I cant manage that figure, I dropped a tenners worth in the other day, just got the needle to a quarter of a tank, ive driven her for approx 50 miles and thats being optomistic and the fuel light is alredy on, not good at this time of year/month when i,m skint. HO HUM :roll:
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
Fri Dec 28, 2007 2:21 pm
TRANSPORTER wrote:WOOOOOWWWWWW 130 miles on a tenners worth of fuel, how do you manage that
I manage better than that !! LPG!
