what diff???????
325dude
allo all just been in the scrappy at the weekend and there was a 325 in there with what i belive is a lsd here is the code off the plate any ideas??????? S 3,64 167 does this mean anything to any one ..................cheers............j
Jimbob
Nah not LSD mate...
....what scrappy is it in btw?
that's a 3.64lsd dude.
M3Compact
LMAO.Jimbob wrote:Nah not LSD mate...
It's a 3.64 LSD mate.
325dude
erm dont mean to be daft is that a good diff?..............j
Jos
Most desirable diff for most e30 owners. Get it quick and don't tell anyone where you saw it
'94 e36 tree climber
325dude
thats ok then cos i out a fiver down on it as i did the lsd diff check try turning one wheel while one is on the ground and id didnt turn so i had an incling but wasnt sure...............j
325dude
would it be worth getting it reconditioned ????? and if so any ideas where?.........j
Ziggy
To be honest... no! Well not 'til you've tried it anyway... Otherwise a cheap diff just becomes an expensive one!325dude wrote:would it be worth getting it reconditioned ????? and if so any ideas where?.........j
Andy335Touring
Just fit it to see if its noisy,if its not just put some fresh LSD oil in it from the dealer.325dude wrote:would it be worth getting it reconditioned ????? and if so any ideas where?.........j
I think some one said they are about 300 quid to refurb depending what needs doing ?
M3Compact
Agreed, they're very reliable/robust diffs when used with standard powerplants.Just fit it to see if its noisy,if its not just put some fresh LSD oil in it from the dealer.
325dude
erm ok will give it a flush then some good diff oil then try it thanks fellas...........j
Andy335Touring
Is that plus parts ?M3Compact wrote:Ԛ£100 - Ԛ£120 labour for a full strip/rebuild/LSD set-up.
I've got a noisey 3.25LSD from an M3 that could do with fixing at some point.
M3Compact
Yes mate, it's Ԛ£100 - Ԛ£120 for the labour charge. It's around 3 - 4 hours work for a complete strip down and rebuild.Is that plus parts ?
The replacement oil is nearly as expensive as new bearings.
A1BMW325iSport
anyone know how much diff oil is from bmw?
is there a part number for it?
also what is the oil capacity in the diff?
Andy335Touring
Thanks for the info i'll bear it in mind.M3Compact wrote:Yes mate, it's Ԛ£100 - Ԛ£120 for the labour charge. It's around 3 - 4 hours work for a complete strip down and rebuild.Is that plus parts ?
Do you rebuild them your self ?
_____________________________________________________________________
It's about 40 quid for two litres,just take a container down with you for them to decant it from there bulk oil drums.Just ask for LSD dif oil.
M3Compact
I have done, and I'm not a wizard with the spanners.Do you rebuild them your self ?
The rally car workshop usually build mine now, mega experienced competition gearbox/diff guru. I've had so many PMs and emails from various sources about rebuilding LSDs, that I asked at the workshop for a fixed price rebuild service. Ԛ£100 - Ԛ£120 is the price and they're 5hit hot. (They're nothing to do with me financially/commercially, rallying is my hobby only.)
Any good quality fully synthetic LSD specific oil is ok for these diffs, they're excellent ZF LSD units, as used in many non-BMW applications. (Ford Capri, Opel Manta etc.)It's about 40 quid for two litres,just take a container down with you for them to decant it from there bulk oil drums.Just ask for LSD dif oil.
Personally, for a standard road car I'd be tempted to use a cheaper LSD oil.
