still discovering things!
				Cloggy Saint
				Gwynleym10
 - Contact:
- orangecurry
have you spotted the holder for the petrol cap in the back of the petrol flap?
				cliffybabe
 - Powered by Nelly
orangecurry wrote:have you spotted the holder for the petrol cap in the back of the petrol flap?
				DaveGT
 - Contact:
I found that out at a petrol station after the motor for it packed up DOH!!
									Health and Safety Officer: "What would happen if a cameraman were to slip over?"
Clarkson: "Well, he'd probably have to stand back up again"
				Gwynleym10
 - Contact:
Thats for parking on the side of the road facing oncoming traffic. having 1 light on saves the battery a bit. My mums '79 polo did this!d6dph wrote:I found out the other week that the indicator stalk has a position which puts the sidelights on on one side of the car (up for rh side, down for lh side)
				dom-1984-320i
grantfk10 wrote:I found out that if I don't push so hard on the right hand pedal, my petrol lasts longer!
The obc has some strange quirky added features too: http://member.rivernet.com.au/btaylor/B ... tions.html
				Jesus325iTouring
 - Frog freak !
Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
A little tip - if your central locking stops working, and locks your petrol flap, you can still unlock it by going through the boot - there is a little cut out in the trim which you can poke your finger through, and press a little catch to unlock it.datourer wrote:After nearly 5 years of ownership I've just discovered that my petrol cap locks with the central locking! I have to push the cap in for it to catch properly, but it's a little bonus anyway. What next??
- grantfk10
 - E30 Zone Meets/Events Team
When my central locking packed in, I managed to open the petrol flap by easing the little locking rod back with a credit card.A little tip - if your central locking stops working, and locks your petrol flap, you can still unlock it by going through the boot - there is a little cut out in the trim which you can poke your finger through, and press a little catch to unlock it.
- Brianmoooore
The more I read threads like this, the more I think some of you ought to invest in a copy of the original owner's handbook!
				cliffybabe
 - Powered by Nelly
bazza93 wrote:i found out if i don't touch the brake peddle i go faster!!!!!!![]()
If your car battery goes flat in deadlock or your drivers door lock seizes up (someone tries to break in), go to the passenger door and turn the key to unlock slightly and hey prest in you go. It will move the lock motor enough to get in !
									What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
				noney82
i did that and hey presto there was my torch, charged it up and boom it worksJesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
				noney82
do these work?320iSE wrote:The obc has some strange quirky added features too: http://member.rivernet.com.au/btaylor/B ... tions.html
				kempo_perth
my ex hates my car as well thats why shes now my ex had 2 make a choice between a burd or ma car and hey the car doesnt answer back
- Estoril-5
 - Contact:
this is a joke right?noney82 wrote:i did that and hey presto there was my torch, charged it up and boom it worksJesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
				Jesus325iTouring
 - Frog freak !
No mate,straight up an that,someone told me about it sometime ago,I checked and there was my torch,been there for at least four years!Estoril-5 wrote:this is a joke right?noney82 wrote:i did that and hey presto there was my torch, charged it up and boom it worksJesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
handpaper wrote:I only discovered last week that turning the headlight switch dims/brightens the instrument backlighting.![]()
Problem sorted then!!!
- Brianmoooore
Not a joke at all - I even found two inside one I stripped recently!Estoril-5 wrote:this is a joke right?noney82 wrote:i did that and hey presto there was my torch, charged it up and boom it worksJesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
				nickso
 - Location: Go do that voodoo that you do so welllllllll!!
i agree with that....i found a manual in the scrappy. took it home and read lots of cool info i never knew.Brianmoooore wrote:The more I read threads like this, the more I think some of you ought to invest in a copy of the original owner's handbook!
including my seemingly pointless second indicator flasher on the clocks......was bugging me for weeks why it was there and why it only flashed once. its part of the towbar electrics and apparently tells me my indicators on the trailer/caravan are actually working everytime i use them.
'88 e30 328i M52 track bint.
				noney82
putting a torch to it is sometimes what i feel like doingEstoril-5 wrote:this is a joke right?noney82 wrote:i did that and hey presto there was my torch, charged it up and boom it worksJesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
indeed.bimmaman wrote:You mean the pull out knob? Surely not...??handpaper wrote:I only discovered last week that turning the headlight switch dims/brightens the instrument backlighting.![]()
something i only discovered after reading this thread! something else pointless to twiddle with when i'm bored
cheers,
harry
						harry
Had a fiddle with my knob this morning...harry_p wrote:indeed.bimmaman wrote:You mean the pull out knob? Surely not...??handpaper wrote:I only discovered last week that turning the headlight switch dims/brightens the instrument backlighting.![]()
I can't beleive I never noticed that before! I wondered why my dashboard was so dim!
It's specifically designed to test the brightness or otherwise of the owners...
