have seen this on a few e30 so i know its not just mine
passenger side rear of sr panel has scrape marks on it as if it catches on something when the roof is open
any idea what causes this??
cheers
Daz
sunroof scrapes?
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
maxfield
I has happened on my dads
Did happen before aswell
Must be something inside?
dazleeds
- old skool raver
seen it soooo many times
surely someone has got round to sorting it and has the answer
bmwe30mtech
Daz, just lower the rear of the panel a few mm's. Im guessing you know you can adjust the height by loosening the torx bolts. May work.
316eyes
Isn't there an article on the yank site for adjusting the sunroof panel, to the exact spec.?
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
dazleeds
- old skool raver
tbh the panel looks spot on flatbmwe30mtech wrote:Daz, just lower the rear of the panel a few mm's. Im guessing you know you can adjust the height by loosening the torx bolts. May work.
and the amount of scraping there is i dnt think it would solve
think i need rooflining out and have a proper butchers at it
its gonna have to come out to do sunroof drain so guess i'll have to leave it till then
maxfield
Tell me your findings please
