New to the forum E30 with a difference
MarcosBMW
Post Thu Feb 08, 2007 11:48 pm
Hi, I'm new to the forum and my E30 323i is very different in that it is fitted in a Marcos sportscar c/w original 5 speed box.
As this unit only puts out 143BHP as standard, I want to swop motor for a 325i thereby increasing power to 170BHP.
Would appreciate any suggestions as to:-
a) Reputable sources to get a good secondhand motor
b) What to watch out for when inspecting such a unit
c) Will this unit fit straight onto my existing g'box (which came from the 323)
d) should I stick with fuel injection or swop to carbs
e) next step for increasing power....
Appreciate your vast knowledge on this site, many thanks.
MarcosBMW
P.S. How do I post a picture on this forum so you can see unit in the car??
ShineOn
Post Fri Feb 09, 2007 7:53 am
Upload the picture to something like www.photobucket.com. Once you've done that, under the picture will be three links, copy and paste the bottom of the three tags into a post on here, and hey presto your picture will appear.
candyman
Post Fri Feb 09, 2007 9:06 am
Hi marcos have good 129 k engine that you are welcome to hear running and purchase if u are near to kent !!
Stuart
IF YOU CANT BE CAREFUL BE SIDEWAYS :D
Ziggy
Post Fri Feb 09, 2007 9:25 am
MarcosBMW wrote:Hi, I'm new to the forum and my E30 323i is very different in that it is fitted in a Marcos sportscar c/w original 5 speed box.
Oooh that sounds tasty! :ttiwwp:
The 'for sale' section on here, well established sellers like JonB, or checkout people's feedback in the feedback thread.
Cracked heads must be the main one! Oil mixing with water, mayo etc... If they tell you it's just had the headgasket done, chances are that wasn't the problem anyway. Unless you really trust the seller, it obviously makes sense to see it running first if possible...
Erm... not 100% sure but I think so!
Unless you're desperate for some old skool carb action, & accompanying gorgeous sound, injection really is better.
E30zone chips, 6 branch manifolds, Big bore throttle bodies, air filters (decent ones), cams, maf / MS conversions, turbos...!
Not sure about the vast bit, but no prob!
MarcosBMW
I use imageshack.us - it's pretty self explanatory! Just post the direct link between tags like this: {img}http://linktoyourpic.jpg{/img}, but use square [] brackets not curly {} ones.
MarcosBMW
Post Fri Feb 09, 2007 10:56 am
Try this, from Imageshack, if it works I'll post pic of engine in situ
bimmaman
Post Fri Feb 09, 2007 11:00 am
Nice... :cool:
I always thought they looked a little odd from behind though... :?
Got any other pics??
MarcosBMW
Engine this time, followed by other views of car......
Bit different isn't it?
What do you thinK?
winkeye
DaveD
E30Zone Wiki Specialist
Post Fri Feb 09, 2007 11:01 am
this might be better...is it one of the wooden ones
copy the other links not the thumbnails for a bigger pic
MarcosBMW
Post Fri Feb 09, 2007 11:03 am
Nah!
I have one of those too, but it's in bits and powered by a F**d Xflow.
Don't think the wooden chassis will take the power etc of Beemer engine....... I'll just continue to "play" with this steel chassis car.
Ziggy, thanks for your advice and information, much appreciated
Ziggy
Post Fri Feb 09, 2007 11:10 am
Now that looks sweet :cool:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Feb 09, 2007 11:19 am
:drool:
Geeman
Post Fri Feb 09, 2007 11:25 am
Marcos looks great.
Never seen an M20B23 looking like that though... is it on a custom intake system? 8)
MarcosBMW
Post Fri Feb 09, 2007 11:26 am
CHeers cliffybabe(?)
I know when I'm not wanted, but sometimes it's nice to be different.
Hope you're not indicative of E30 owners in general.
Geeman
Post Fri Feb 09, 2007 11:28 am
MarcosBMW wrote:CHeers cliffybabe(?)
Huh?
Cliffy was drooling over your car dude! :cool:
I come from a background of kit cars... Dad and I have built a Hornet (first attempt at kitcar-dom... never again!), a Chesil and a Hawk 289.
Now he's a bit older, he's gone for a TVR... winkeye
MarcosBMW
Post Fri Feb 09, 2007 11:37 am
Sorry, thought he was puking!!
Apologies cliffybabe
Intake system is "custom" out of necessity, to fit into engine bay area. Unfortunately KN filter will only fit behind radiator so when engine running hot it sucks in hot air, reducing power. Need to re-think that, but probably only after have updated to 325 power.
d6dph
Post Fri Feb 09, 2007 11:41 am
Welcome to the zone.
That's beautiful. An old customer of mine had an LM400 (i think?) which was awesome, he decided in his infinite wisdom to remove all silencers. Sounded mega :twisted:
That intake looks interesting, I guess it's to drop the height of the engine over the std m20 inlet system. Does it still use the std air flow meter?
Keep us updated on your choice of engine. :cool:
MarcosBMW
Post Fri Feb 09, 2007 11:54 am
"Does it still use the std air flow meter?"
It appears to, so I guess that might be a problem powerwise also. Having said that, because she weighs so little she still goes pretty well and with a custom stainless (mostly) exhaust, that 6 pot sounds very sweet.
I believe there are only two BMW-engined Marcos in the world.
I like her anyway
Will keep you updated on engine and F.I. Choice. Presently talking to Fritz Bits as Richard there seems very knowledgeable
E30Mark
Post Fri Feb 09, 2007 11:59 am
I have a complete 325i engine and all anciliaries for sale :D
Where are you based? I assume SW area if your talking to Fritz'
PM for details
d6dph
Post Fri Feb 09, 2007 12:02 pm
May be worth speaking to Ant about having megasquirt fitted when the new engine goes in. Then you can ditch the AFM flappy restrictive gayness and go to a MAF and the great throttle response that it brings. Also would enable you to get the best from what mods are fitted.
toby
Post Fri Feb 09, 2007 12:09 pm
Megasquirt I think would help you get around any wiring incompatibilities that may exist between the 323i and 325i. It also alows real live tuning.
e21Jason
Post Fri Feb 09, 2007 12:42 pm
Hi
I see you are runing k-jet so i guess the engine is from a e21 323i, drop in a e30 2.5 and megasquirt and you will be about 180+ over the stock 140, the easy and quick bolt on upgrade.
Nice car by the way doess it have the adjustable brake pedals i always thought that was a nice touch on the Marcos.
That car needs a 2.7 if not more at least and if you are intrested i may have a set of tripple 45 webbers for sale soon (along with a 2.7 engine)
MarcosBMW
Post Fri Feb 09, 2007 1:28 pm
e21Jason wrote:Hi
Adjustable pedals including brakes and clutch, via a moving box, are absolutely essential.
Why? Because the seats fit straight into the body leaving no possible adjustment in the normal way.
Thus pedals are adjusted to suit driver.
Not sure about going to 2.7........ but does sound tempting with a set of Webers.....
Now I'm drooling
2.5 + megasquirt sounds more like it
:mad:
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 09, 2007 3:53 pm
MS running true Alpha N/MAP hybrid would mean no AFM or MAF, more power, better response and lots more room for a decent cold air feed.
M20B25 + MS= superb intake noise, ask MattG :lol:
Welcome to the zone BTW dude, JazzMan has a B25 in his Merlin Roadster :cool:
andyp
True Old Skooler
Post Fri Feb 09, 2007 7:37 pm
Hi mate and welcome,
your right it is different
drifty325i
Post Fri Feb 09, 2007 10:28 pm
Thats mint, would like to see more pics of the intake
