Bilstein Streetline Kit
Turbo-Brown
- Boost Junkie
Has anybody had any experience of this kit?
Tweekies sell them for about Ԛ£250 so it sounds like a fairly economical way to lower my car (bog spec 325i) but if it's not worth the bother, I'll have to throw more money at it.
Any thoughts appreciated!
Cheers!
Cheers!
When i have the money i'm gonna save that extra Ԛ£100 and go for the sprintline kit
ed325i
Hi, I have fitted these they are a bit bounce on the front. I would throw more money at it.Turbo-Brown wrote:Has anybody had any experience of this kit?
Cheers!
ED
M5pilot
Streetline is just standard Bilstein shocks + Cheapo springs.
Apex kit is much much better.
Sprintline kit is soft aswell, really not impressed.
Best thing you can do is buy a H&R kit. if its too low then go for H&R springs @ Ԛ£110 + any decent shocks. Boge mtec stuff is actually very very good. Bilstein sports work out at about Ԛ£350 so thats really expensive.
willow
Bilstein sport dampers + Eibach Pro springs - at least that's what was recommended to me when I spoke to a very nice chap at Motorsport World today - works out a bit more expensive, but apparantly worth it
Save the E30s!
Karan
ive had 'leaky experiences with the streetline kit.... they were crap as were the springs which were harsh yet still soft......
Demlotcrew
Ive got bilstein sports and they are very good! I would not put anything else on any of my cars. The high speed cornering/stability is just amazing.
(i know that its not only the dampers that contribute to cornering ability)
Andrew
Andrew
M5pilot
Bilstein Sport shocks are excellent. I think H&R kit uses them to H&r spec.
Alot of money though but worth it.
Has anyone used the sportline kit as a whole it can't be bad! i'm still gonna take the plunge and try it!
Bharat
Bilstein Sport dampers are really good, but sadly a bit too stiff for the poorly maintained roads in this country.
Sachs/Boge M-Tech specification dampers are an extremely good option, and if you have the money, H&R is the way to go.
The Bilstein Streetline kit has good dampers, but the springs are crap, and most people (BMW and non-BMW) who have tried it have usually thrown those springs away (think they are Ventura branded)
325i Motorsport Edition convertible - gone, but not forgotten.
it does say on the adverts for the streetline kit it's for people on a "budget"
Demlotcrew
Si you should get the Bilstein Sports all round, then some H&R prings to match, this is the best combination around for your needs. It wont be worse than the ride you have now. It might be softer. $$$$$
Andrew
Andrew
Bharat
Make that mega $$$$$Demlotcrew wrote: $$$$$
Andrew
Bilstein Sport dampers =
and the 10mm rubber thing in the front strut?! PM'd u too dude
Demlotcrew
Bharat they are worth every penny, you know how long it took me to save up for them!
Si i dont know if you would need the cup for the front with the H&Rs
Pmed u back
Andrew
Pmed u back
Andrew
M3Compact
I have a pair of brand new rear Bilstein rear dampers for sale, Part No: B36-2027, are these the 'sport' ones?
Here.
Here.
Demlotcrew
Yes.M3Compact wrote:I have a pair of brand new rear Bilstein rear dampers for sale, Part No: B36-2027, are these the 'sport' ones?
Here.
M3Compact
Thanks.
Are these the best Bilstein E30 rear dampers you can get without buying a full kit?
Demlotcrew
Yes, these are used by AC/Alpina/Early Sports/Hartge/H&R.
They are very good, they are auto adjusting (both on rebound and compression) and have a life time warranty.
Andrew
Andrew
hoshy
- E30 Zone Wiki Guru
Any comment on the spax psx kit? 40mm drop all round but it's really stiffness on a budget I'm after.
I'm gonna buy in the next week or so, so any cheap and stiff advice would be great. Just in case I'm barking up the wrong tree, I'm looking for something to minimise the body roll when (trying to go) sideways.
Cheers, Ashley
Cheers, Ashley
hoshy
Sorry for double post.
A quick google also shows the avo chassis Dynamics kit (35mm, non-adjustable) as the mid-price between the bilistien streeline (no longer an option) and the psx kit which is damping adjustalbe.
Again, though and comments?
Karan
if u dont wanna go too low like with the h&r kit..... then id recommend the shocks demlot has with h&r -35mm springs.... demlots car corners very well having followed him from behind... and although its still high'ish' is very very good....
Karan
Karan
Demlotcrew
Dude like i said to you i was trailing that Type R and his inside rear wheel was off the ground, and i was still on power! I just need that Hartge ARB on the rear to balance out the understeer a bit!
It all adds up.
Stiff springs will reduce body roll, (also the car wont slide as much) but you need to have good dampers to match the springs. A E30 with stiff lowering springs and stock dampers will be out handled by a E30 with stock dampers at the stock ride height.
Andrew
It all adds up.
Andrew
Simon
Anyone used these before??
http://www.shox.com/
Bilstein sport shocks work out at just over Ԛ£200, are they the proper sport ones??
nadz325i
Andrew
koni wound up full im sure will give a stiff ride to reduce body roll? matched with hr springs?
hoshy
It's not that I don't want it to below. I'm just not bothered about how low it is. I'd rather have some hardcore stiff, quality shocks that sit high but let me fly round corners than some super low shocks that are shit.Karan wrote:if u dont wanna go too low like with the h&r kit..... then id recommend the shocks demlot has with h&r -35mm springs.... demlots car corners very well having followed him from behind... and although its still high'ish' is very very good....
Karan
h&r seem to be recommended all over the zone but from what I've seen I don't think I can afford them. Budget *stretches* to about 350. with 250 being the ideal money I'd be looking to spend.
M3Compact
DanJones
Ive got the kit on mine and i would also spend more money and get a more expensive kit..... I dont find the streetline kit hard enough as it uses standard shocks so i would prefer a kit with stiffer, shorter shocks to give a harder ride....They arent too bad if you really cant afford anything more expensive as i have had it on my car for 8months now and it hasnt frustrated me too much....
Demlotcrew
Koni only adjust on rebound. and alot of people question their build/parts quality.nadz325i wrote:what about Koni vs Bilstein shocks?Demlotcrew wrote:
Andrew
Andrew
willow
I've been looking for a price for the bilstein sport dampers for my 325 se -but so far I can only find them for cars with M-tech and not without?
Heres the link
Bilstein Sport Shocks
What's going on? Can you only get the sport shocks for the 325 sport or what?
Heres the link
Save the E30s!
hoshy
for what it's worth I've decided on koni sports. out of my budget atm so I'm getting them after the end of the month.
oohh can't wait. and in the meantime I'm gonna go for the z3 shifter.
anyways back on orig topic: I could only see the same bilstiens as you willow. Getting my konis from the same place though. They seem to have good prices, I've been looking at alot of suspension recently!!! hoep the boss doesn't find out
Demlotcrew
Ԛ£120 each for the front.willow wrote:I've been looking for a price for the bilstein sport dampers for my 325 se -but so far I can only find them for cars with M-tech and not without?
Heres the link
Ԛ£75 each for the rear.
This is Dampers only.
willow
Where did you get those prices from Demlotcrew?
>Edit...sorry spelled your name wrong
Save the E30s!
Demlotcrew
You can get them for less, the rears i got for Ԛ£114 inc vat for two. But that was with blags and discount cause i wanted it.
Andrew
Andrew
