***Wishbones***
BIGJO
Post Wed Jan 10, 2007 10:29 pm
Doing some work on my Sport & was considering changing the wishbones. Now, i'm not too sure whether I should go for BMW, GSF or any other manufacturer? Wondering if anyone actually has experience.
Regards, BJ.
aus325
Post Wed Jan 10, 2007 10:39 pm
Front control arms are produced by a few different companies... LEMFOERDER, OCAP, and MEYLE.
I chose Meyle when I replaced mine, the Lemfoerder's where quite a bit more expensive (I'm not exactly sure what the differences are, maybe better quality ball joints?). The original items on my car were Meyle.
BIGJO
Post Wed Jan 10, 2007 10:44 pm
Cool. That helps, thanks fella.
Anyone have any knowledge about these manufacturers? And how they compare with BMW?
Regards, BJ.
Templ8e30
Post Wed Jan 10, 2007 10:47 pm
Original BMW wishbones are Lemforder or Febi
www.eurocarparts.co.uk sell the Lemforder (the more expensive of the 2 types they sell) and www.gsfcarparts.com sell Febi, again the more expensive of the 2 types they sell.
These makes have better longer lasting balljoints than the other cheaper makes.
Don't forget that you'll need the wishbone bushes too.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
BIGJO
Post Wed Jan 10, 2007 11:15 pm
I've ordered the Powerflex bushes from Sal but contemplating on which wishbones to go for.
Which manufacturer is the best? Assuming Lemforder & Febi?
Regards, BJ.
GDBN
Post Thu Jan 11, 2007 8:30 am
You'll be fine with Febi.
I deserve 6 of the best ...
MadE30mike
Post Thu Jan 11, 2007 9:23 am
I have got slightly more camber on my front left wheel than the other side, would a bent wishbone cause this?
Chris-W
Post Thu Jan 11, 2007 9:26 am
Could do - might also be the bush, damper or spring.
Post Thu Jan 11, 2007 5:47 pm
Powerflex? :puke: they have a nice habit of breaking rather quickly and un expectedly :eek:
M3 solid bushes job done
Royalratch
Post Thu Jan 11, 2007 6:03 pm
You changing the balljoints or the wishbones BigJo?
New wishbones, also known as control arms, come with new balljoints installed in them already.
4 x balljoints (2 for each arm) costs almost as much as new wishbones when you factor in paying to have them pressed into your old wishbones. It's only worth doing if you have special (alloy) wishbones like the M3's and late 325i Tourings have.
You will also want to change the control arm 'mounting bracket' bush, also called the lollipop. There are choices there such as regular, solid and offest solid. You'll have to press those into your old bracket as they do not come with bushes in them and are damn strong anyway so you shouldn't need new brackets.
Lemfoerder and Febi are both OEM suppliers to BMW so both are fine, though Lemfoerder seem to have produced more so maybe are a bit 'posher'. There are threads on here that explain the difference and maybe someone with more knowledge can give you details.
Poweflex bushes are pretty stiff and may last longer - they are kind of aimed more at track users and I've heard are noisy as they transmit more vibration/sound.
Don't forget to get your wheels tracked after all of this straight away.
march109
Post Thu Jan 11, 2007 6:04 pm
who stocks m3 solid bushes?
whats the performance difference between these and stock and powerflex?
Whats the cost difference?
march109
Post Thu Jan 11, 2007 6:08 pm
RoyalRatch thanks, answered some of my questions before I posted!
Royalratch
Post Thu Jan 11, 2007 6:09 pm
M3 bushes are rubber.
Powerflex are a polymer/plastic material.
M3 bushes are about £40 a pair? You can also use E36 one's.
The other decision is whether to get offset or centered. Offsets tweak out your camber/steering geometry a bit and give better turn in and feel, though I can't claim to know too much about that.
I installed solids because I wanted a stronger/tauter set-up.
Post Thu Jan 11, 2007 6:14 pm
Royalratshit, you can't press new ball joints into an M3 aluminium arm, it will break as they are too soft. Only on the standard Iron arms can you do this.
M3 solid ones? BMW only i'm afraid. The bmw bush is the best as it will last the longest, give the best ride and best steering feel as it alters castor slightly, plus something else i can't remember. I paid around £90 for a pair and that was a trade price also! But they are worth it
The only downfall for want of a better word is it moves the front wheels back, some people think this looks funny when the wheels are pointing straight ahead. The rims can rub a little with big aftermarket wheels on full lock. they are quite expensive too, but you will never have to replace them tbh
powerflex? hmmm i can think of 3 cars which had these fitted and they all feel apart literally within weeks of being fitted. None of these cars went on track after they were fitted before someone asks! Powerflex are just crap if you ask me.
Stock are ok if your not worried about lowering or track days or cornering faster than the stock setup allows, plus they are not expensive either.
Royalratch
Post Thu Jan 11, 2007 6:22 pm
So when M3 balljoints go you have to replace the whole wishbone?
Chris-W
Post Thu Jan 11, 2007 6:24 pm
Yep.
Post Thu Jan 11, 2007 7:06 pm
and at over £200 per arm it's not very funny!
thats why no touring on the roads today have them fitted still when you can get a standard arm for £38 from GSF
Simon
Post Thu Jan 11, 2007 8:49 pm
Even most M3's have the steel arms now :o:
The M3 bushes can also be bought from C3, though I haven't checked the difference in price from BMW.
BIGJO
Post Thu Jan 11, 2007 9:54 pm
Who are C3 Simon?
Am I to go for M3 bushes over Powerflex? With either Lemforder or Febi wishbones?
Regards, BJ.
Chris-W
Post Thu Jan 11, 2007 9:56 pm
Post Thu Jan 11, 2007 9:59 pm
Sal will say powerflex but it's up to you badboy, we can only advise
be warned C3 sell some non genuine sh!te, check before you buy
stuartgallafant
Post Thu Jan 11, 2007 10:05 pm
dips told me that you is a way of getting the old bushes out and the new bushes into the alloy wishbones.
you have to use the old hot and cold method apparently, using a hot air gun or blow torch (very carefully, mind you) and a freezer. Like interferance fitting, but using the opposite method to remove it i suppose
i dont know if this definately works, i was a bit sceptical myself, but you never know!!
Post Thu Jan 11, 2007 10:09 pm
well it's worth a punt on some knackered arms. I thought something like that aswell once upon a time. Heat them up on removal. But you would also want the arms hot for refitting. Surely it's less likely to fracture if the arm is red hot. Maybe they will distort. Aluminium is a bitch sometimes
but is it worth it for half a kilo! i know it's more really.
Stu one phrase "staff discount"
Jamesb318is
Post Thu Jan 11, 2007 10:10 pm
I've had powerflex bushes on my car for well over a year now with absolutely no problems - must have been a faulty batch?
I'm pretty sure the eccentric bushes push the wheels foward in the arch aswell.
stuartgallafant
Post Thu Jan 11, 2007 10:14 pm
Si, the staff discount isnt worth it mate! things like that cost me nearly full whack, coz they just dont sell them!!
but as you say, its worth trying on a set of arms that may be f*cked? the thing is, where do you get the replacement bushes/balljoints from?
beardymat
Post Thu Jan 11, 2007 10:16 pm
Simon13 wrote: The only downfall for want of a better word is it moves the front wheels back, some people think this looks funny when the wheels are pointing straight ahead. The rims can rub a little with big aftermarket wheels on full lock. they are quite expensive too, but you will never have to replace them tbh
i know someone who has these fitted and his wheels are further forward, has he got these fitted the wrong way round (offset hole to the outside of the car instead of the inside)
Post Thu Jan 11, 2007 10:21 pm
I read somewhere that there can be fatigue problems with elderly aluminium arms as well.
Post Thu Jan 11, 2007 10:22 pm
:? why the wrong way? does it handle ok?
Chris-W
Post Thu Jan 11, 2007 10:23 pm
Brianmoooore wrote:I read somewhere that there can be fatigue problems with elderly aluminium arms as well.
It would make sense - an old, stressed alloy casting.
stuartgallafant
Post Thu Jan 11, 2007 10:42 pm
maybe i wont bother then?
Royalratch
Post Thu Jan 11, 2007 11:05 pm
stuartgallafant wrote:dips told me that you is a way of getting the old bushes out and the new bushes into the alloy wishbones.
Forged Aluminum does not react well to rapid heating and cooling. If there are any cracks or blemishes in the wishbone, no matter how small, they will be amplified.
£200 is no joke for each arm either. I can't believe BMW would make them and not make the rubber replaceable? Are the alloy arms supposed to only last the life of the rubber, like proper Motorsport parts?
I mean, most BMW's from E36 on have alloy wishbones don't they?
stuartgallafant
Post Thu Jan 11, 2007 11:21 pm
i know how tempremental aluminium can be!!
i think its easier from a workshop point of view to make the bushes/balljoints unchangeable?
its a PITA though!!
Post Thu Jan 11, 2007 11:27 pm
Royalratch wrote:[. I can't believe BMW would make them and not make the rubber replaceable? Are the alloy arms supposed to only last the life of the rubber, like proper Motorsport parts?
Rubber bush is replaceable. It's the two metal balljoints that aren't.
Royalratch
Post Thu Jan 11, 2007 11:29 pm
The balljoints on M3 wishbones are metal?:eek:
stuartgallafant
Post Thu Jan 11, 2007 11:34 pm
Royalratch wrote:The balljoints on M3 wishbones are metal?:eek:
yeah!! you couldnt have a rubber ball rotating inside a rubber cup, could you?!
