WHERE CAN I GET A VERNIER PULLEY FOR MY 2.7 BUILD?
DORAS
I need to get an adjustable vernier pulley for my m20 2.7 project it woll be going on a schrik cam.
Can anyone help?
Rich
Can anyone help?
Rich
kam-325i
Demon Tweaks ?
E30Adam
Yeah agreed Jim, I got my Kent Cams verner from Halfords, they'll have to oder it in though and they need modding ever so slightly.
--alpina--
hi all, just a quick question, the vernier pulley is the sole part of advancing a performance cam for the 0-60?? thats the idea i had, as on performance cams the power bandwidth takes effect around 3-3500 rpms,, but by advancing it it would effectivly come cut in earlier.. this way you lose top end... also a way to time up bottom to top parts of engine as regards to performance the timing wouldnt match (timing marks), is there any other benefits of a vernier pulley???
J.
J.
Templ8e30
The whole idea of a vernier pulley is to allow you to set the timing perfectly.
Nowt to do with 0-60 times.
For example, if you build a 2.7 using 325i pistons the block needs to be shaved. This means that the cam pulley is closer to the crank pulley giving retarded cam timing. A vernier will be needed to correct the cam timing.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
chu346
What is the proceddure for setting the timing with one of these?
Templ8e30
You need the spec from the cam manufacturer and a timing disc. To get it spot on you also need a DTI (dial test indictaor) to detect true TDC and maximum lift.
Have a look at http://www.symuli.com/vw/camp1.html and
http://www.symuli.com/vw/camp2.html
also http://www.4cycle.com/karting/html/timi ... eeing.html
Cheers,
Iain T
Cheers,
Iain T
--alpina--
Cheers guys, that exactly what i thouht...i had a kent vernier pulley and i advanced it so i can get 0-60, and it did make a massive difference, thats when i had distributor in the car, but now a motronic setup so i couldnt put the pulley on, totally different....
J.
J.
kam-325i
How does shaving the block alter the timimg ?
i can understand using the vernier to advance/retard the cam......but why do you need one in the first place ?
Jimbob
Shaving the block would alter the distance between the pulleys on the cambelt...surely that speaks for itself about timing being out.
The vernier pulley is adjustable - i.e if the block is shaved, there is slack in the cambelt due to the slightly shorter distance, increase the size of the vernier pulley to overcome this
kam-325i
But is the timing governed by the gearing ratio of the pulleys and not the distance between them ?
if ive got 2 pulleys, raito 4:1, regardless of the distance between them, the raito will still be 4:1 ?
Is it caused by the teeth on the belt not lining up ?
mrLEE30
i am with Kam on this, the pulley does not affect timing, but only allows you to take up the slack in the belt, the timing is fixed by the teeth/belt relationship, otherwise this would mean if i shortened the swingarm on my bike (without removing the chain) and used the same chain/sproket combination the gearing would change..... no i did not think so either!! i would however have a slack chain so remove links (or shorter timing belt) or fit a device to take up the slack (vernier pulley)
mrlee
mrlee
Vernier pulley is necessary to take up the slack in the belt on the tension side caused by skimming the head or block. Tensioner pulley adjusts to take up the slack on the return side of the belt, plus the slack from the tension side transferred there by the vernier pulley.
If the crank and cam pulleys, and the tensioner were locked in place before any skimming was done, the belt would be slack on both sides when you put it back on. Slackening off the tensioner bolts would allow the slack to be taken up on that side, but not the tension side, so the outside of the vernier pulley is then turned without moving the centre to transfer this slack to the return side where the tensioner spring can take this up as well.
I suppose if you skimmed off an amount equal to the pitch of the belt teeth, then a vernier pulley wouldn't be needed.
Any thoughts on belt tension? The spring won't be pushing as hard on the tensioner in its new position.
kam-325i
Ah...got it now.........
Fit the vernier, turn vernier "back" to transfer all slack in belt to the tensioner side.....without affecting the position of the cam......
Not really - that's just to illustrate what you're doing. Correct way is with dial gauges etc., as mentioned above.kam-325i wrote: Fit the vernier, turn vernier "back" to transfer all slack in belt to the tensioner side.....without affecting the position of the cam......
