Not mine mate (M3 in the background gives it away), I found the pics and thought I would post em as it does look a nice bit of platekam-325i wrote:Its likely to fall off.......Aluminium welding is not very foregiving like steel....I would personaly recommend you grind out those welds and put a bit more power into it, around 180-200A.
Im not so sure. Just seems to me that some weak points have been introduced.DanThe wrote:but you cant deny that it adds strength to the sump for skimming over speed humps etc,
