Questionaire/Survey E30 M20 Head Problems/Performance
buckz2001
MOTORSPORT STUDENT MAJOR PROJECT E30 325 M20 CYLINDER HEAD
Questionaire/Survey:
1:Can you please inform me the mileage when yours or a friends 325's had Cylinder Head problems?
2:Problem incountered?Reasons why:
3:Do you feel the standard M20 325 E30 power/performance requires improving to match todays hot hatches?
4:Do you feel porting/polishing the head could help stop overheating problems that lead to cracks etc? Please give reasons:
Thanks for your time filling in this questionaire.
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
How many threads do you want!
Theo
Is the 885 head really that bad? I've had 4 325's 75k, 198k, 175k and 125k - none of them have had head problems... Never experienced any temperature problems either, even when giving the car hell round round the Ring the temp needle didn't go above 1/2 way.
pnd
heads tend to go between 100-150k in my experience the earlier cars seem to be less prone to this but not immune Theo you have been lucky Ive had several go. on the last one the temp didnt rise just used coolant and this eventually started mixing with the oil. as for performance these engines are not easy to iomprove a six branch and chip is all you can easily do. I am not a fan of cams cos you lose bottom end torque and they are detrimental to smooth running at idle.
oguz327
- Captain Armco
137,000 miles on mine and owned for the last 3.5 years and so far no problems even after a ring trip and several other track days. Like all engines regular servicing and coolant changes should keep things sweet.
Had two m20 e30s and they have both been fine however i did cook an e21 320 head once but these were notorious for overheating.
Probably most 325 heads never crack, but a good proportion do.
IIRC, one theory for the cracking is the large cast iron exhaust manifold bolted up to it, and fitting a six branch can alleviate this.
Andyboy
- Alpina Colada
Most of mine were perfectly okay. A couple mixed oil and water and a couple used to run hot, probably due to head gasket/water jacket corrosion issues. A huge proportion on E21 and E12's needed new heads early on.
buckz2001
thanks for the advice guys.....the manifold weight theory is interesting!
cheers
cheers
320Touring
Andy, you deviant- so many 520i's
my 320i is on original head, standard manifold, 104k and no problems- coolant changed every 12 months
Andyboy
- Alpina Colada
In know. You haven't lived until you've experienced the raw power of a 12v M20 520i E34 Automatic. They're so slow they're dangerous - the first time I drove one I thought the handbrake was on.320Touring wrote:Andy, you deviant- so many 520i's![]()
320Touring
I can imagineAndyboy wrote:In know. You haven't lived until you've experienced the raw power of a 12v M20 520i E34 Automatic. They're so slow they're dangerous - the first time I drove one I thought the handbrake was on.320Touring wrote:Andy, you deviant- so many 520i's![]()
drink like ollie ried on a bender too, no doubt
Nothing to do with the weight. It's the amount of heat it feeds back into one side of the head that's supposed to be the problem.buckz2001 wrote:thanks for the advice guys.....the manifold weight theory is interesting!
cheers
Andyboy
- Alpina Colada
I think it's more like an inconsistency with head castings. Recently I saw a 1981 320 with it's original head and they were the ones most prone to cracking. I have a feeling E12's and E21's had a two piece (old M30 style) manifold which would have some more flex. The old metal bumper 325i's were buggers for cracking manifolds too. I've seen 325i's with @100k and full history that have cracked heads so there really is no rhyme or reason for it. Possibly a variation in alloy quality? It's odd how some heads corrode badly and others don't.
Either way - start squirrelling away those M20 heads now!
reggid
head cracking mostly comes from not bleeding the coolant creating air bubbles the cause increased cyclic heating and cooling which is what fatigue cracks need to initiate and then grow. Every time you top up coolant use genuine stuff and bleed it and you'll minimise the liklihood of cracks. Also keep the entire cooling system in good order and flushed regularily.
If statistical analsis was ever done IMO the climate would play a part if its cold the temp range becomes higher and the head will cool faster which can cause thermal shock in rare cases which may start the initiation process.
If the 6 branch alleviated cracking then i wouldn't have a cracked original german delivered Alpina head
miniblob
Ha ha, my head went after i had my 6 branch fitted - no idea if it's actually cracked or what though 'cos it's still in use at the mo - just very creamy!!!!! To answer your survey, i think it was on about 112k or 113k when it started using water - now it's nearer 120k and using sh*tloads of water - and plenty of oil!!
327 Touring with bass!!!
Andyboy
- Alpina Colada
Would a 6 branch manifold absorb/dissipate anywhere near as much heat from the head though? Just a question. The thing about air locks doesn't really stand up because cars which have been running fine on proper anti freeze do it. There are two cracks to consider - the normal one where it cracks under the cam (oil and water mixing) and the other one from an exhaust port into a waterway. Buckz should get an old M20 head and saw it in half to see the cross section of the head. I did once - I'll go and find the pic.
e30_Turbo
- Boost Junkie
Andyboy
- Alpina Colada
Here's a 325i head sawn in two;
reggid
whats antifreeze got to do with preventing air bubbles?Andyboy wrote:The thing about air locks doesn't really stand up because cars which have been running fine on proper anti freeze do it.
Anyone ever tried this stuff instead of head replacement? http://www.steelseal.com/eng/home.html
Sounds like a nice lazy way to fix them...
Andyboy
- Alpina Colada
What air bubbles? The only reason for there to be air bubbles in a cooling system is a faulty head or head gasket! You'll also find antifreeze has vastly less surface tension than straight water so it moves around much easier - or so Glycol say.reggid wrote:whats antifreeze got to do with preventing air bubbles?Andyboy wrote:The thing about air locks doesn't really stand up because cars which have been running fine on proper anti freeze do it.
Andyboy
- Alpina Colada
That looks good! The other stuff is Seal-it, a satchet of alloy flakes you tip into the cooling system. Not as good as piston cement though. How to make a completely shagged Nikasil engine run again - well, long enough to sell the bastard!320iSE wrote:Anyone ever tried this stuff instead of head replacement? http://www.steelseal.com/eng/home.html
reggid
why is there a bleeder valve then?Andyboy wrote:What air bubbles? The only reason for there to be air bubbles in a cooling system is a faulty head or head gasket! You'll also find antifreeze has vastly less surface tension than straight water so it moves around much easier - or so Glycol say.reggid wrote:whats antifreeze got to do with preventing air bubbles?Andyboy wrote:The thing about air locks doesn't really stand up because cars which have been running fine on proper anti freeze do it.
reggid
but what does it actually doBrianmoooore wrote:To fill it from empty.reggid wrote:
Andyboy
- Alpina Colada
It's not a bleed valve. It doesn't open and close. It's a bleed SCREW. You use it to let airlocks out when you fill or refill a cooling system after it has been drained.
reggid
Andyboy wrote:It's not a bleed valve. It doesn't open and close. It's a bleed SCREW. You use it to let airlocks out when you fill or refill a cooling system after it has been drained.
definition of a valve "any device for halting or controlling the flow of a liquid, gas, or other material through a passage, pipe, inlet, outlet, etc"
so it is actually a valve that works by a screw mechanism and it does open and close (but not automtically) otherwise you couldn't be bleeding anything.
Why do you want to get airlocks out given that the definition of an airlock is
"A bubble or pocket of air or vapor, as in a pipe, that stops the normal flow of fluid through the conducting part"?
Self explanatory, I should have thought!reggid wrote: Why do you want to get airlocks out given that the definition of an airlock is
reggid
i actually know what its for its just some others have saidBrianmoooore wrote:Self explanatory, I should have thought!reggid wrote: Why do you want to get airlocks out given that the definition of an airlock is
" The only reason for there to be air bubbles in a cooling system is a faulty head or head gasket! "
which is not true and if there is a air lock then it can affect the cooling system and hence cooling of the head which must have some effect on the heads life.
All i know is that all the BMW specialist engine builders around here have said to me that bleeding the system after replacing fluids or top ups is critical for this reason
Andyboy
- Alpina Colada
Jesus, it really is 'spot the brain cell' today isn't it!!
"" The only reason for there to be air bubbles in a cooling system is a faulty head or head gasket! "
which is not true"
So please DO tell O Wise Maestro why this is not so? Where do all the air bubbles in a pressurised cooling system come from? I'm sure we'd all love to know...........
which is not true"
reggid
they come from when you fill the coolant up from empty or near empty. If there are no bubbles and the system is properly pressurised then yes a fault with the head gasket or head will cause airlocks but these are not the "only" reason for there to be airlock during the cars life.
WillG
isnt it a problem cos people think its full when they fill it up put cap on and drive it and air has come out they are low on collant and overheat, when i change collant i normaly fill it up leave cap off and start it from cold and keep filling it up as it goes down till it stops, put cap on and drive till its close to running temperature, turn it off and then let it cool back down and check level. Done this on everything i worked on and never had problems. So is it really possible to get an airlock and it stay there forever until you bleed it?
Andyboy
- Alpina Colada
What Reggid, you mean like this?Andyboy wrote: You use it to let airlocks out when you fill or refill a cooling system after it has been drained.
Airlocks and air pockets don't occur in a healthy engine. That's why the header tank is above the cylinder head.
reggid
show me an m20 engine thats healthy..........lolAndyboy wrote:What Reggid, you mean like this?Andyboy wrote: You use it to let airlocks out when you fill or refill a cooling system after it has been drained.
