I want to know what you fella's think regarding these kits, if youve had them fitted to you car etc.. and can you tell me the best between the two. Please dont comment if your only going by "the name" these two brands are as good as eachother, so im told. with the konis you have the extra advantage of top adjusting, for hard / soft ride. but with the h&r kit shocks are just matched so im led to believe. (i may be wrong). I really only want to lower the car 40mm as i feel the weight of the m30 will be more than enough to push it down an extra 10mm at the front
Right... what should i spend £400 on.... KONI kit or H&r Cupkit?
thanks everyone
