2.5 block with 2.0 head
Timo21
Hi Guys
Iv got a 2.5 Sub assembly with a 2.0l head.
Iv lined up all the marks, put the timing belt on, but
the crank rotates about 45 deg. then feels like its hitting a valve.
Could the cut cam have anything to do with it or cant a 20l head work
on a 325 sub..
on a 325 sub..
Richy325iTouring
320 head wont work on 325 bottom end
johnono
sorry i diddnt read before i posted
Andyboy
- Alpina Colada
It won't turn over. Ever. The 325i pistons have a raised front lip, 320i ones are flat. The 325i head has a machined raised section in the combustion chambers to accomodate the 325i raised crown pistons, 320i heads don't. Sorry mate but you need a 325i head!
I have two, in case you need one...........
bottlecapE30
it should work if you shave 3mm off the pistons.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Andyboy
- Alpina Colada
And weaken the piston crown.........
No, really NOT a good idea!
Just fit a 325i head and do it properly.
trigger
you can always have the piston crowns pocketed to clear the valves, quite a common practice , piston crown thickness allowing ! of course.
trigger
just out of curiosity what do you think you might gain using a 320 head instead of a 325 head taking into consideration what machining might be involved that would just as easily be undertaken on the 325 head?!
Andyboy
- Alpina Colada
Pointles tho - the valve cutouts aren't the issue and the 325i cutouts are more than big enough anyway. When you can buy a 325i head for £509-£100 it's all a bit pointless!trigger wrote:you can always have the piston crowns pocketed to clear the valves, quite a common practice , piston crown thickness allowing ! of course.
kam-325i
Are'nt the valves on the 320i head smaller than the 325i head ?
kam-325i
So why bother then ?????
Andyboy
- Alpina Colada
Exactly! It's a lot of work in order to lose power.
trigger
andyboy, does this mean that the piston crowns at tdc are higher than the top face of the block, if so is it still possible to skim head to raise compression ratio? without having to have crowns machined as ive yet to see inside my 325 head, new to them you see.
Andyboy
- Alpina Colada
Yes. That's why only a 325i head will fit. If you machine too much from a 325i head the piston tops will clout the head - look on the head face and there are some small round recesses. These are skimming marks. Skim past these and you're in trouble. Basically, don't skim the head unless you absolutely have to, such as when doing a head gasket.trigger wrote:andyboy, does this mean that the piston crowns at tdc are higher than the top face of the block
