fast e30
jamesroools
i got bored the other day and worked out (mathematically.. yes im sad
) that a 327i with approx 200bhp and 200lb/ft, and had the kerb weight of the car reduced to about 900kgs, then it would do 0-60 in sub 6 seconds, like arround 5.5 seconds, this seems rather fast for very little effort, just wonderd if anyone thinks this would actually be possible
Adammcf
To get it to 900kg's you'd have to strip a hell of alot off the car.
jamesroools
i know, but if it went that quick, it would certainly worth it
BIGMRLEE
not that av nowt beta to do but, i`ve had same sort of thoughts nd it is possible but you`d be driving a shell with not many panels so you get more wind resistance.
Custom and Classics
.Design .Restoration
.Repair .Modification
& Custom Builds
07901602663
LeeHatfield25@btinternet.com
CAR`S, VAN`S, BIKE`S & 4X4`S
Body repairs, bodykits, painting, welding,
exhaust systems. M.O.T repairs
Servicing,
& Custom Builds
07901602663
Servicing,
jamesroools
what about a carbon fibre body? bit pricey though
BIGMRLEE
have to be custom built carbon fibre cos no companies want to know
Custom and Classics
& Custom Builds
07901602663
Servicing,
& Custom Builds
07901602663
Servicing,
jamesroools
yeah prob wouldnt be worth the work, but theres still alot that could be done to reduce weight, especially if you went to extremes
Sjoerd320i
ive seen a site that sels carbon body panels like , dash, doors, boot, m3 front bumper, front wings also m3, hood.
edit: doors are door cards
2nd edit: i found the site
http://www.e30shop.de
can't think of the site anymore
6potWil6pot
Youd probably save a fair bit of weight with Perspex plastic windows instead of glass!
jamesroools
wouldnt that be impossible to clean, and if it got scratched it would need replacing, but if it was gonna go that extreme it wont be that bad
redz
Just stick the lump on a scotter, and watch it fly.
jonb
i think you will have your work cut out trying to cut an e30 down to 900kg"s.
ok for a track day special, but useless as a road car. better off buying an e34 m5.
E30Adam
I seem to remember that Duncan stripped his E30 out and still couldn't get it under 1,000kg's and he was pretty much driving a shell with running gear.
He also had problems with finding springs that allowed it to be low enough. Because it was so light, it sat quite high even on very low springs so there are lots of other things to think about if you're going ot the extremes.
