e30 m3
iil325i
Post Sun May 14, 2006 11:28 am
right whats the difference between the eary and late e30 m3's i know that the early ones have 195 bhp and the late have 215 bhp, but is there any thing else
Matt_T
Post Sun May 14, 2006 11:50 am
Small technical differences here and there, nothing major tbh except for the engine head.
billgatese30
Post Sun May 14, 2006 1:35 pm
i think things like the colour options for the seat material changed slightly pulus one or two other things but not much, not sure about suspension differences other than some of hte very early ones didn't have eccentric control arm bushes i think but i'm not sure, enven if they do, its not hard to do and most would have been done already
other than that i think it was just the engine that differed
Simon
Post Sun May 14, 2006 5:45 pm
The headlamps changed when the normal E30 had it's facelift too.
iil325i
Post Sun May 14, 2006 5:48 pm
im on about big things, like the tec1 and tec 2 are so dif
there isnt anything that makes and older one not as good otherte than the engine is 20hp down
Rich_W
Post Sun May 14, 2006 6:07 pm
iil325i
Post Sun May 14, 2006 6:13 pm
i was tring to get on there all morning
Demlotcrew
Post Sun May 14, 2006 6:29 pm
Lee 20bhp between the engines it alot!
Ive driven a 195bhp early model and it felt totaly dead! If i ever got one the first thing it would get is a Engine upgrade.
Andrew
iil325i
Post Sun May 14, 2006 6:35 pm
not that worryed about the engine m8,
sac1974
Post Mon May 15, 2006 10:28 am
There is hardly any difference between them, they all have the same bodyshells, glass, panels etc, some really late cars have different style cloth.
EVO II and EVO Sport are much different with lightended glass and body panels.
215 cars have 48 throttle bodies were as the 200bhp car has 46mm
195bhp cars are the same as 200bhp engine.
My car is a 195 bhp cat model but remapped at bexley motorsport, i am now producing 210bhp. To get a remap costs about 350 but it transforms the car.
There will be no difference between my car and a 215bhp model and very slight difference to a EVO II or Sport EVO
Also keep in mind that a well looked after 195bhp car is much better than a battered and mis treated higher BHP car.
Demlotcrew
Post Mon May 15, 2006 1:08 pm
The Evo II has lighter Rear quarter windows and boot, but nothing else! Where as the SE has far more weight savings.
I can assure you that a Evo II will be alot faster than your 195 model and a SE will wipe the floor.
It would be interesting to find out how Bexleys managed to get another 15bhp from your car.
Can you post a pic of the Dyno Graph?
Andrew
c76jon
Post Mon May 15, 2006 2:22 pm
evo 2 also has lightened rear screen
bumpers are lighter
also evo 2 has diff flywheel,diff cams,higher compression,different diff
additional rear spoiler,alloy bottom arms
chin spoiler
etc
some of these became standard on later cars but none on earlier 195 cars
there are far more differences than at first glance
Matt_T
Post Mon May 15, 2006 4:44 pm
But were talking about a 215 evo, not an evoII here. The 215 had the alloy bottom arms but not the splitter or double rear spoiler.
c76jon
Post Mon May 15, 2006 5:31 pm
Matt_T wrote:But were talking about a 215 evo, not an evoII here. The 215 had the alloy bottom arms but not the splitter or double rear spoiler.
like i said some bits were carried over to later cars
no such thing as a 215 bhp evo
john
M5pilot
Post Mon May 15, 2006 6:20 pm
I have to agree with Demlot here.
I have owned a D reg 190 odd BHP car and the current 215 bhp model I have now.
The is a very noticeable difference in power above 4000rpm. Ant had the chance to drive both aswell and said exactly the same thing.
Matt_T
Post Mon May 15, 2006 6:41 pm
c76jon wrote:no such thing as a 215 bhp evo
john
Well mine is a late spec 215, and is labelled as an evo in the log book :?
c76jon
Post Mon May 15, 2006 7:05 pm
ok
evo 1 was early car with no plaque in car.proven by markings on head when they were new
vins
Evolution I 2190005 - 2190787
evo2 had plaque 500 cars made and one special order convertible that was full evo2 spec
vins
Evolution II 2191372 - 2191376
2191409 - 2191473
2191477 - 2191479
2191481
2191483
2191485 - 2191487
2191489 - 2191491
2191493
2191500 - 2191502
2191504 - 2191506
2191510
2191511
2191513 - 2191515
2191517 - 2191518 2191520
2191524
2191526 - 2191528
2191530 - 2191534
2191536 - 2191541
2191543 - 2191546
2191548
2191550 - 2191554
2191556
2191558 - 2191560
2191562 - 2191564
2191566 - 2191567
2191569
2191571 - 2191573 2191576 - 2191592
2191595 - 2191614
2191616 - 2191805
2191807
2191809 - 2191832
2191834 - 2191839
2191841 - 2191840
2191850 - 2191852
2191854 - 2191856
2191858 - 2191911
2191913 - 2191953
evo 3 (evo sport) again plaqued car and 600 made
vins
Evolution III AC79000 - AC79599
evo1 was 200hp car built 2/87 to 5/87
evo2 was 220hp car built 3/88 to 5/88
evo 3 was 238hp car built 1/90 to 3/90
there wasnt a 215 hp evo car so iam guessing its an addition to your logbook by previous owner/importer
your car is obviously a late one
evo2 red cars were misano red
evo3 were brilliant red
hth
john
iil325i
Post Mon May 15, 2006 7:14 pm
as i found out last night the interior is poo on the early ones,
Demlotcrew
Post Mon May 15, 2006 7:31 pm
c76jon wrote:evo 2 also has lightened rear screen
bumpers are lighter
chin spoiler
etc
Forgot about the bumpers John! Looking at the ETK its only the acual carriers under the bumper are different but the actual 'trim' pannel is the same on all models except SE cars with the front lower spoiler molded into the trim.
But im sure engine wise the only differences between the EvoII and the stock 215bhp ones is;
As fitted to EvoII engines
Sprocket
Smaller Throttle bodies
High comp Pistons
Lighter Fly wheel
Both engines have the same cams just that the Evo II has a sprocket which retards the timing on the exhuast by 6deg.
Andrew
c76jon
Post Mon May 15, 2006 7:52 pm
bumpers are lighter
chin spoiler
etc
Sprocket
High comp Pistons
Lighter Fly wheel
Andrew
yes i agree about the carriers just easier to say bumpers i guess
i stand corrected on cams
i knew sprocket was different but thort one of the cams were too
the throttle bodies have some trick mating to head dont they?
i know they are 46 but wasnt there some slight difference somewhere??
john
Demlotcrew
Post Mon May 15, 2006 8:48 pm
The throttle bodies are only specific to the EvoII the inlet track is 46mm but where it mates to the head the throat is borred out to 48mm. Its a very trick casting by BMW and some say were fitted to the 320is early Rally cars.
Andrew
c76jon
Post Mon May 15, 2006 8:56 pm
yep i knew there was some trickery going on in there
thanks mate
john
