New member - just saying hello
SD
Fri May 05, 2006 7:24 pm
Hi all,
Just become the proud owner of an H-reg 325i Touring.
Have been browsing the zone recently and it seems like there is loads of good info on here - car is in good nick, but there will be some niggles to sort, so will be around here to look for advice!
Cheers,
Scott
fuzzy
He who sleeps with "Gingers"
Fri May 05, 2006 7:25 pm
welcome mate,tourings are the way forward,any pics? :thumb:
Conan
Fri May 05, 2006 7:41 pm
:ttiwwp:
'91 Sterling Silver e30 320i SE
'96 Avus Blue e34 525i Sport
'92 Alpine White e30 318iS Touring
'86 Alpine White e28 M5 (008/187)
'02 Titan Silver e39 530d Sport Touring
'54 Cosmos Black e61 535d MSport Touring
'07 Sapphire Black e61 M5 Touring
Andy335Touring
Fri May 05, 2006 9:08 pm
:wave:
pete320i
Fri May 05, 2006 9:09 pm
hi and welcome to the forum, they are a good lot on here. have with the car mate.:cheers:
320i dolphin grey.
panesar_e30
Fri May 05, 2006 9:24 pm
any pics of the car mate? :cool:
stevetigger
Fri May 05, 2006 9:43 pm
:tongue:
zaust
Zone day release
Fri May 05, 2006 9:47 pm
Welcom to the zone fella...
pic's pic's pic's...
M30 Tech 1 Touring on gas.
eko
Old timer
Fri May 05, 2006 9:55 pm
Welcome mate :)
So whats your plans for the tourer?
Standard or modified?
SD
Tue May 09, 2006 8:37 am
Well, didn't take long to find the first "niggle". What initially looked like a small oil leak turns into Niagara falls every time the car is parked pointing uphill. Not a drop if nose down. Searching on here it would appear to be the sump gasket or rear crank seal?
Oh well, c'est la vie, knew I wasn't going to get away scot free. Am going to get it booked in the garage to take a look - and they can do the timing belt while it's in.
Otherwise, the plans for the Touring is to get it to the point where it can do exactly what it says on the tin, and take us touring! Just want to make sure it is mechanically sound, and then can look at improving.
Sorry no photos yet - but, it's Brilliant Pink with 15" BBS's. Will get some up as soon as I can take some without it looking like the Exxon Valdez! :D
Hyperion
Tue May 09, 2006 8:58 am
Welcome SD, Sounds like a sweet ride, tourings are cool :wink: Sorry to hear about the oil leak thou :cry:
e30_Turbo
Boost Junkie
Tue May 09, 2006 10:48 am
SD wrote:Well, didn't take long to find the first "niggle". What initially looked like a small oil leak turns into Niagara falls every time the car is parked pointing uphill. Not a drop if nose down. Searching on here it would appear to be the sump gasket or rear crank seal?
Welcome :D
And sounds like the sump gasket to me, the last few nuts by the bell housing are only hand tightened by the garages, mine had worked loose and the gasket had popped out.
Easy to find, just take out the 4 bolts on the access panel under the gearbox and have a look.
If it needs changing you'll need to drop the front beam to get enough clearence to clear the oil pickup, also lifting the engine from above may give you a extra inch or two....
And we'd all like that wouldn't we :lol: :lol:
Ant
Retired Team Member
Retired Team Member
Tue May 09, 2006 12:04 pm
:lol: @ Fozz
speak for yourself mate :wink:
Welcome to the zone fella !
put your location in your profile and you may find a lot of zoners local, always handy !
M5pilot
Tue May 09, 2006 12:09 pm
Welcome to the Zone!
Tourings are the in thing these days, get some pics up.
Ziggy
Tue May 09, 2006 1:25 pm
Welcome! Look forward to seeing it at a meet sometime? There's quite a few of us in the area! :D
SD
Tue May 09, 2006 5:47 pm
Thanks guys.
Unfortunately, the oil leak brings bad news...
http://www.e30zone.co.uk/modules.php?na ... ic&t=34992
