4 to 2 head light conversion?
appletree
Post Sun Apr 23, 2006 7:43 pm
just wondered if anyone had gone from 4 front head lights to 2? i went to motor world the other day and picked up a huge bass port for £2.99 is exacaly the same sixe as the hole in the front grill so i thought i would take the inside light out and replace it with the port and then put some ducting to my K&N.
i know you can do it on the MK11 golfs but i just wondered if anyone had done the convesion before????
ed325i
Post Sun Apr 23, 2006 8:11 pm
Yes it can be done.
maxfield
Post Sun Apr 23, 2006 8:12 pm
Thats a photoshop but i think it can be done search
ed325i
Post Sun Apr 23, 2006 8:17 pm
maxfield wrote:Thats a photoshop but i think it can be done search
Is it? I found it on e30.de
ED
Andy335Touring
Post Sun Apr 23, 2006 8:23 pm
Sorry for the slightly O/T but where can you get those bass ports and how big do they go ?
I want one 3 1/2 to 4 inches diameter to use as an inlet trumpet on an air filter box, a bit like this but bigger.
stevetigger
Post Sun Apr 23, 2006 8:25 pm
Andy335Touring wrote:Sorry for the slightly O/T but where can you get those bass ports and how big do they go ?
It says, Motor World!
Andy335Touring
Post Sun Apr 23, 2006 8:28 pm
ah, i didn't read it properly :roll:
bottlecapE30
Post Mon Apr 24, 2006 1:26 am
The 2002's only had two lights i would look for 2002 light upgrads.... i bet hella has something
good luck
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Demlotcrew
Post Mon Apr 24, 2006 7:32 am
Andy i dont know if a bigger inlet trumpet will yield more power, it might actually loose you low end torque.
Andrew
Post Mon Apr 24, 2006 2:32 pm
doubt it Andrew, its only the inlet to the airbox, the rest of the induction system will dictate air speed and therefore low end torque
Post Mon Apr 24, 2006 2:37 pm
Jhonno wrote:doubt it Andrew, its only the inlet to the airbox, the rest of the induction system will dictate air speed and therefore low end torque
you would be surprised how much low end torque you lose by pulling the little plastic trumpet out of a standard airbox
Post Mon Apr 24, 2006 3:37 pm
this is true Lee, my alpina only had a K&N so i put an airbox on, but it was missing the trumpet. I've got one now and it runs better, goes a bit better too and makes some induction noise!
Andy335Touring
Post Mon Apr 24, 2006 5:01 pm
Some back ground info..........
The trumpet in the picture is from a stock M30 air box, the trumpet at the narrowest point is about 50mm.The M30 TB is about 64-65mm so the trumpet is 15mm(ish) smaller and probobly wouldn't cause any form of restriction on a standard M30 with an AFM.
My engine doesn't have an AFM and it has the capacity to suck a bit more air in than standard as it has had the head ported and a schrick cam.
I'm hoping that the biggest restriction in the engine(apart from only having 2 valves per cylinder etc lol) releasing more power now is the standard 65mm TB.
I am eventually going to be fitting a twin 60mm TB from a Ford V8 and the standard M30 air box to my M30 to help it breathe better to squeeze some extra bhp out of it.
The Twin 60mm TB has the surface area equivelent(sp?) to a single 85mm TB so the stock trumpet on the air box is going to be to small so i want one 75-85mm.
Demlotcrew
Post Tue Apr 25, 2006 8:17 am
The trupmet acts like a venturi to accelerate the air as it enters the chamber. You should see the F1/DTM inlet trumpets!
I understand your theory Andy.
Andrew
buster
Post Tue Apr 25, 2006 8:26 am
Andy,
do you need that inlet manifold milling flat for the t/b ?
If so you post it here and back and i 'll mill it for you.
Post Tue Apr 25, 2006 11:22 am
Andrew
furry muff
my mistake, now i think about it makes sense
Post Tue Apr 25, 2006 1:28 pm
one thing i noticed years ago when i was a kid racing karts was that when i went up from racing in what was called "junior brittain" now 100A I think, was that we were running a 25mm butterfly carb, instant snapping performance when you nailed it. with the right gearing at 3 sisters at Wigan we would see 100mph down the straight.
When i moved up into a class for age 16+ (100 National) you had a 40mm slide carb and there was just no bottom end.
The trick was to squeeze in the power rather than just stab it as that caused it to bog down. Took a bit of getting used to. Once it was up the revs and singing at 15000rpm upto max revs it really kept going.
Andy335Touring
Post Tue Apr 25, 2006 5:53 pm
buster wrote:Andy,
Thanks a lot for the offer mate but i think i will only need to get it roughly flat because i'm going to get a spacer plate welded to the manifold then bolt the TB to the plate.
It needs a spacer plate because the throttle mech' on the TB will catch on the manifold.
Andy335Touring
Post Tue Apr 25, 2006 5:57 pm
E30BeemerLad wrote:one thing i noticed years ago when i was a kid racing karts was that when i went up from racing in what was called "junior brittain" now 100A I think, was that we were running a 25mm butterfly carb, instant snapping performance when you nailed it. with the right gearing at 3 sisters at Wigan we would see 100mph down the straight.
Thats one of the problems with carbs, with fuel injection you can work around with the fueling to get it running right.
buster
Post Tue Apr 25, 2006 6:54 pm
buster wrote:Andy,
I see,ok no probs. :D
fuzzy
He who sleeps with "Gingers"
Post Tue Apr 25, 2006 9:24 pm
whats the legal position on removing the 2 inner lights come mot time?
stevetigger
Post Tue Apr 25, 2006 10:18 pm
fuzzy wrote:whats the legal position on removing the 2 inner lights come mot time?
I'm sure its ok, When I took the E30 for an MOT.....The guy didn't check the alignment of the full beams.
stonesie
Post Tue Apr 25, 2006 10:48 pm
True, the alignement is not checked but i think they have to be there.
I will check the book tomorrow if nobody has answered by then :wink:
i think you would need different lights with the H4 bulbs, the golf's actually have these in the outer lamps and the inners are just spot's wired into the main beam so theres no mot issues with removing the inner lamps with these.
