I need to replace a couple of brake pipes at the rear. I was going to by a kit - but what size pipe and fittings do I need please?
Brake pipe size
flybynite
4.75mm pipe and M10 fittings. If you don't get them as a ready made kit then make sure you do the correct flare and do the job right and get cupro/nickel (Kunifer) not copper
In real money its 3/16 inch tube, as advised definitely buy cupro/nickel tube
Phid
Yes thanks - I’ve bought the cupro nickel pipe.
reggid
Also fittings are bubble type
E30 325is with M20B31
