Hi guys
I am changing the two fuel pipes that come into the engine from below the car. Doesnt anybody the diameter or size of these pipes? Its the pipes bringing the fuel to the engine. And the approx lengths of these?
Am i better off buying new from a shop or from a breaker?
Yaad
Fuel hoses
biffer
Sizes are 8mm internal diameter/13mm outer diam., and i found 2m was enough to do my car which has fuel-pump just in front of rear wheel.
I avoided Ebay stuff and got Gates hose from local factor for about £4 per metre.
Halfords sell this hose for about £7 per. m.
Or BMW sell it for gawd-knows-how-much.
yaad
Perfect, halfords have one with internal diameter 8mm but external , would 2mm external make a difference
twenty
Someone mentioned these are perfect fit. And E10 compatible. https://www.ebay.co.uk/itm/382558398973
As for me, they were all redone using genuine hoses from BMW. Probably more expensive but it’s a safety critical part so I didn’t want to gamble.
BMW supplied hose is much better quality than anything you will find in a motor factors and will undoubtedly last longer too
Bonymaenjack
Brianmoooore wrote: ↑Fri Mar 05, 2021 2:11 pmYou are contemplating fitting second hand rubber hose????
I think (hope) he was asking for advice
twenty
Do you know if the BMW hoses are E10 compatible? I didn't check when I fitted mine but I do hope that the spec has been upgraded from the original design from 30 years ago
yaad
Thanks for the advice guys! I ordered some from BMW after your recommendations
Should last many years now
