Trunk lid trim panel
coopman
Was the trunk lid trim (part 51491916246) standard spec?
tha881
Bonymaenjack
Still available I believe , I replaced mine 3 years ago from the dealer and no they're not cheap
coopman
Around EUR260
Don't think I'll get one, but I was interested because I didn't even notice I was missing anything until I stumbled across the RealOEM diagram. I don't think I've ever seen an E30 in real life with the trim.
Unless your car is a SE, then you're not missing anything.
coopman
Good stuff, thanks.Brianmoooore wrote: ↑Tue Sep 01, 2020 2:01 pmUnless your car is a SE, then you're not missing anything.
tha881
paultv
I've got one.
Paul
Paul
Always considered it a bit odd that this part wasn't fitted to all E30s, considering how well the rest of the boot is trimmed out. It's an area that's on show to the world every time the boot is opened, and without the panel it detracts from the whole image of quality that should exude from these cars.
twenty
I was thinking of putting sound deadening metrial on the trunk lid but I guess this won't be too bad.
Satan
I have one fitted to my E30, sprayed it black....... will take photo next time I visit the car.
minesapint
Satan
Sort off, locked away in a garage complex a few minutes from home.minesapint wrote: ↑Wed Sep 23, 2020 8:24 pm“Visit the car”...............is it in an old folks home?![]()
I bought mine on a wim a few years back, will take a photo tomorrow as I need to refit the rear bumper rubber.
coopman
I also noticed that. I'm going to stick with one strut in mine - the weight reduction helps keep my 0-60 time below a minute.
minesapint
minesapint
They do look unfinished after seeing yours Paul!
paultv
Car came with spoiler on the boot lid and 2 struts...also listed on real oem as two struts fitted...boot won't stay up with one anyway...even with correct new struts in place, its the extra wright of that inner cover.
Paul
Paul
Satan
Mine was "tatty" with the cracks in the usual places so I painted it with a vinyl spray.
paultv
I see you're missing the plastic cable guide for the horseshoe release.
Paul
Satan
BenHar
Later cabriolets were fitted with two struts because the single strut pushed the boot up on that side when it was closed and messed up the shut lines.
Ben
Ben
Satan
minesapint
Bloody Hawkeye!!
You are absolutely correct........I have never noticed that before. Had a look this afternoon, if it ever had one I have never seen it, & am at a loss to know why.
I’m wondering if it’s ‘pulled through’ behind the trim panel, I’ll take it off to investigate.
I’ve also looked on RealOem & cannot identify the part. Would you please take a close-up picture for me.
minesapint
Kind of........it’s a crude interlock which stops the horse-shoe from opening if the boot lid is raised, as they would hit each other.
Do these boot lid trim panels weigh a lot?
Satan
If the boot is open and you open the horseshoe it drags the boot lid down and if the horse shoe is up and you open the bootlid it closes it.minesapint wrote: ↑Thu Sep 24, 2020 8:53 pmKind of........it’s a crude interlock which stops the horse-shoe from opening if the boot lid is raised, as they would hit each other.
Satan
I need to pop to Screwfix tomorrow and if it's not raining will take the E30 out so will take a photo, I also used the same paint on the under dash panel, it came out ace.
coopman
paultv
Hawkeye..........are all your expanding rivets in place on your hood compartment trim panel?
Nope - some are missing - well spotted!!
Paul
Paul
BenHar
https://www.realoem.com/bmw/enUS/showpa ... Id=41_0805minesapint wrote: ↑Thu Sep 24, 2020 8:42 pmBloody Hawkeye!!
Ben
minesapint
Thanks for that but I’m still unsure which the part is?
BenHar
Do you have either of the cables present?
The plastic guide is part 17.
Ben
Ben
minesapint
Okay thanks.
Looks as though it’s still available!
