Welded Diff - are drum brake drive shafts strong enough?
Lemon98
Post Mon Apr 06, 2020 5:07 pm
I'm more than likely going to get my standard 1990 320i open diff welded in the next month or two and want to ask what the factory shafts are like?
I know that 325's had an LSD as an option and that drum brake and disc brake cars have different flanges but are the shafts themselves any different and therefore will I come into trouble driving a welded drum brake diff?
It's not going to be a drift car or driven sideways everyday but for the odd bit of sideways exiting a junction or around a roundabout I can't afford a new LSD currently and am bored to be honest. So want to be able to have more fun in the car.
I have the standard 14 inch bottlecaps with narrow tyres.
I'm not looking for replies about the pro's and con's of a welded diff I'm well aware I purely want to know if the driveshafts will cope :) Diff mount is poly and subframe bushes will follow shortly.
TIA
1990 4-door 320i SE
flybynite
Post Mon Apr 06, 2020 7:35 pm
How long is a piece of string?
You could break a lot of bits with a welded diff, just depends on what you do with the left and right pedals really
Post Mon Apr 06, 2020 7:48 pm
You will if your insurance company finds out. Absolutely stupid idea! Either do it right with a LSD, or leave it as it is.
LSD was an option (and a relatively low cost one at that) on all E30s, not just the 325i.
