Paul
As i understand gasless is designed for 3mm thick metal, of course one can weld on thinner, but as you stated it is fierce and more prone to blow through.flybynite wrote: ↑Mon Feb 24, 2020 7:26 pmWhat I found when I tried gasless was it seemed quite fierce and was more prone to blow through than I was used to with the full size kit. It was a while ago but it gave off a stink and not something I would use in a small workshop, don't know if it is something that has improved but maybe something to look out for when demo-ing![]()
A grinder hides a lot but to be honest that looks more than a decent job, your worst would still be better than my bestboiliebasher wrote: ↑Thu Mar 19, 2020 7:08 pmIMG_20200301_185928708.jpg
It gives me decent enough welds. This is the sill on my Range Rover classic I have been welding up in the last few days
Thanks for the kind words. I grew up welding up old fords so well versed in cutting out tin worms out of old cars lol.Bonymaenjack wrote: ↑Thu Mar 19, 2020 10:34 pmA grinder hides a lot but to be honest that looks more than a decent job, your worst would still be better than my bestboiliebasher wrote: ↑Thu Mar 19, 2020 7:08 pmIMG_20200301_185928708.jpg
After being the "proud"owner of numerous mk1 & 2 cortinas I know exactly what you meanboiliebasher wrote: ↑Fri Mar 20, 2020 1:20 amThanks for the kind words. I grew up welding up old fords so well versed in cutting out tin worms out of old cars lol.Bonymaenjack wrote: ↑Thu Mar 19, 2020 10:34 pmA grinder hides a lot but to be honest that looks more than a decent job, your worst would still be better than my bestboiliebasher wrote: ↑Thu Mar 19, 2020 7:08 pmIMG_20200301_185928708.jpg
If you actually look carefully in the photo, my welds haven't actually been ground down at all. It's exactly how they are, I can assure you. They where simply cleaned off with a wire brush and nothing more.
All done on my Clarke 151 te turbo using 0.6mm wire and argon/co2 mix gas. Gives pretty decent enough results and perfect for the average diy'er
Things where cheaper in the 1960's Paul.........
