Prop shaft Identification
Kedge
Post Tue Apr 23, 2019 11:02 am
Hi,
Just wondered if anyone could help identify what model of E30 this prop shaft is from? It’s been sat in my mums garage for years and I can’t remember what I removed it from.
It has the following number on it 1101470.3 & 12064823
Cheers.
Instagram - Kedge85
Post Tue Apr 23, 2019 1:30 pm
Measuring the overall length is probably the easiest way to identify it.
Kedge
Post Thu Apr 25, 2019 4:50 pm
Appears to be a 325i one then, assuming you’re meant to measure right up to the end containing the bushing.
Instagram - Kedge85
Post Thu Apr 25, 2019 6:08 pm
If it's 1489mm from flange face to flange face, and the sliding bit is where it was when it was on a car, then it's a M20B25 manual prop.
Kedge
Post Mon May 06, 2019 8:57 am
Flange face to flange face is 1460mm, no idea whether it’s moved on the splines at all but the collar nut is undone.
Instagram - Kedge85
Post Mon May 06, 2019 8:05 pm
The only reason the collar nut would be loose on a prop. that's been removed from a car is to close it up on the splines to make it easier to remove.
If there's not a lot of spline showing, this is almost certainly s 325i manual prop.
