Got Touring Dyno'd
M5pilot
Post Fri Feb 03, 2006 2:44 pm
Had my 325i Touring dyno'd at Bexley while it was in for brake fluid change on Wednesday.
The reason I had this done is because I fitted one the E30Zone Shop ITG induction kits and felt quite a big difference in midrange torque - it was really apparent in the higher gears. It felt more powerful than most of the 325i's I've had in the past.
The other reason is I wanted to see if this car was a good test bed for other performance parts that are sold through the shop.
The car has no other modifications at all.
It made:
173 bhp @ 5700 rpm
177 lb.ft @ 4100 rpm
I will post up the graphs later but I was really impressed. It did kind of explain why it felt so good through the midrange.
mason
Post Fri Feb 03, 2006 2:50 pm
Must of just missed you Sal
Dropped off my sisters e36 M3 down to Jags picked it up yesterday done a fantastic job
ITG fiter sounds good mate keep up the good work
Mason
stevetigger
Post Fri Feb 03, 2006 4:10 pm
How much does it cost to have a car RR'd
M5pilot
Post Fri Feb 03, 2006 5:48 pm
A rolling rd costs around 35+VAT for a power run.
mason, I saw your sisters car there! Shame I didnt get there a little earlier.
Andy335Touring
Post Fri Feb 03, 2006 11:00 pm
Shame you couldn't get a before and after power run(air filters) ?
M5pilot
Post Sat Feb 04, 2006 11:26 am
I am going to get a before and after run in the next week hopefully - the test needs to be performed with a totally clean OE air filter, my old one was a bit dirty but not very much.
oze30
Post Sat Feb 04, 2006 2:17 pm
Hey Sal,
JonB is getting my engine sorted, so hopefully will be able to do a before/after on the you know whatsee! (As soon as I can save up enough cash and clean my air filter)
M5pilot
Post Sun Feb 05, 2006 12:32 am
Touring now has full scorpion system on it. Got it for 95 notes and its pretty new. My old exhaust I thought was leaking so it was rude not to fit it. Old exhaust turned out to be ok and it was 2 manifold studs loose that caused the blowing!
Anyway, its failry quiet right now - I'm sure it will get noisy after a while!
Definate loss of bottom end torque!!
Cotty
Hartge Crew
Post Sun Feb 05, 2006 11:00 am
M5pilot wrote:
It made:
173 bhp @ 5700 rpm
Thats good
Did you also get an "at wheels figure" when I had mine RR at Surry Rolling Road they couldnt give me a flywheel figure as its an auto but it made 121 at the wheels which they calculated to be 165 at the flywheel
Mine is totally standard at the moment but Ant is putting the Zone chip in this week so will have to get an after figure for it.
M5pilot
Post Sun Feb 05, 2006 3:48 pm
The bexley dyno does show real wheel BHP but it doesnt record it on a graph.
I was looking and it made just over 130bhp at the wheels.
Losses are calculated on the run down and added to the wheels figure through the entire rev range - it is quite accurate.
fuzzy
He who sleeps with "Gingers"
Post Sun Feb 05, 2006 4:05 pm
so it lost 40 bhp in the transmission? thats about 25%, i was told it was only about 10-15% you lost 8O
M5pilot
Post Sun Feb 05, 2006 7:07 pm
You cannot work out losses as a percentage. Its a very very general way of doing things and is highly innacurate. Different cars have different wear in the box and diff, there is difference in tyres etc etc. There are so many variables.
E30 m3's normally lose about 40-50bhp through the tranmission.
Scots car put down around 210rwhp and made 249bhp at the flywheel - that has the same gearbox as me and an open diff.
When I did my dyno run two people had to sit in the back to stop it wheel spinning (cold tyres) hence increasing friction on the rollers.
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 05, 2006 7:11 pm
open diff
sorry, thats just wrong :wink:
vindication
Post Mon Feb 06, 2006 8:44 am
BHP losses
17.9% FWD
24.8% RWD
All taken as average.
M5pilot
Post Mon Feb 06, 2006 8:45 am
ant wrote:
open diff
Oi! Planning on getting LSD soon ok! Your fitting it remember. :twisted:
jonb
Post Mon Feb 06, 2006 9:26 am
sal
what you going to give ant for fitting it? cup of tea and a cake at aces. :?
so lets work this out.
325i touring + air filter thing = 173 bhp
+ special manifold = 191 bhp
+zone keyring = 201bhp
M5pilot
Post Mon Feb 06, 2006 10:45 am
Ants prices are very reasonable and he does alot of extra work at no extra cost - so tea and cake at Aces is well deserved!
173 bhp is so far what its made.
Lets see what the manifold gives along with the Keyring.
If it makes good power then I will take it to another rolling road with a standard 325i for comparison. I know they work and give some excellent gains so have no problems doing this.
I firmly believe near 200 bhp can be achieved from a 2.5 if the right parts are fitted. 190 bhp has been done and dusted with a few mods so its not exactly hard.
Remember, the manifold has had alot of work go into it, ideas were taken from the RD manifold as it was an excellent design to start with.
