E30 Water leak fron under manifold
Ray17
Post Tue Jul 31, 2018 9:49 am
hi guys!!
I am in the progress off finishing my e30 320i cab and which has been parked for a while and started it yesterday and their is water leak from under the manifol!! I couldnt find anything on it on the net so im wondering if anyone else has had this issue previously!!
Thanks in advance
:cry: [/img]
Ray17
Post Tue Jul 31, 2018 9:58 am
Im sure mines leaking from their does anyone know what that part is called?
Satan
Post Tue Jul 31, 2018 10:24 am
Do you have some better photos as to where that is located, looks like rubber wrapped around a pipe and held tight but metal wire.
BTW what year is your car?
Ray17
Post Tue Jul 31, 2018 10:55 am
Its an 1987 i found that on youtube just searching i will get better pics when i take the manifold off tomorrow myself. It on the engine block itself..
Cloggy Saint
Post Tue Jul 31, 2018 12:19 pm
The area shown is the crank breather tube that goes from the crank case to the inlet manifold. It's not unusual to have a bit of oil weeping from this seal but there shouldn't be any water going through it. Assuming you've mistaken oil for water then fit a new rubber O ring. All will become clear when you remove the pipe!
aimlessrock
Post Tue Jul 31, 2018 1:04 pm
whip off the inlet and have a good look around, suspects its got some excess oil residue in it.
E30 320i Convertible (1989)
190 Mercedes (1988)
Ray17
Post Tue Jul 31, 2018 1:28 pm
100% sure its water the i put like 10 litres plus in it but will update you guys tomorow unless its a different pipe leaking and looks like its coming from there but thanks guys!!
aimlessrock
Post Tue Jul 31, 2018 1:32 pm
post some more pictures- this will help.
where exactly did you put these 10 liters of water?
190 Mercedes (1988)
Post Tue Jul 31, 2018 3:48 pm
10 litres is alot of water ! some leak.
Have you messed around with something else ?
paultv
Post Tue Jul 31, 2018 4:55 pm
Is the water being sucked into the throttle body from the more than useless TB heater block, ( rotted out ) then out of the manifold via the crank case breather tube - I'd expect the oil to show signs of water content though.
Just a long shot!
Paul :-)
Satan
Post Tue Jul 31, 2018 5:14 pm
paultv wrote:Is the water being sucked into the throttle body from the more than useless TB heater block, ( rotted out ) then out of the manifold via the crank case breather tube - I'd expect the oil to show signs of water content though.
Just a long shot!
Paul :-)
Mayo in the oil cap?
Ray17
Post Tue Jul 31, 2018 5:20 pm
Just a long shot!
Paul :-)
Nope no water in the oil cap and no sign off oil at all its a water leak it looks like its coming from there
https://www.realoem.com/bmw/enUS/showpa ... Id=11_1167
I had a look at the link and still cant figure what pipe it is
minesapint
Post Tue Jul 31, 2018 6:42 pm
https://www.realoem.com/bmw/enUS/showpa ... Id=11_0117
Part 11.
10 litres is about the capacity of the whole cooling system, implying it was totally empty!
Satan
Post Tue Jul 31, 2018 6:43 pm
Ray17 wrote:
Just a long shot!
Paul :-)
What number roughly?
Satan
Post Tue Jul 31, 2018 6:49 pm
I think it may be PN 11531719788
paultv
Post Tue Jul 31, 2018 7:04 pm
Nope, it's 11151280938 referred to as a "Genuine BMW Pipe"
wonder what you smoke in it?
Paul :-)
Ray17
Post Tue Jul 31, 2018 9:00 pm
Cheers guys you all have been amazing!! Will find out tomorrow :mad:
Cloggy Saint
Post Tue Jul 31, 2018 11:06 pm
How did you manage to get 10 litres of water into it? :?
Ray17
Post Wed Aug 01, 2018 6:34 pm
Hey guys been working on it since the morning it was the the cover lid
Number: 18
Then kept overheating was the viscous fan and a air lock which took hours so filled the water backwards intonthe pipes but its running!!
Thanks for all the help
Ukhozi
Post Thu May 02, 2019 10:41 pm
Keep an eye on the little pipe at the back of the block to the valve, mine leaked gallons before I found it when taking the head of after brewing up.
Everyone has the right to reach the level of their own incompetence.
