auto fluid
Post Tue Dec 26, 2017 12:02 pm
1987 baur 316 4 speed auto
Can I use dexron II or III in the gear box ?
Topblag
Post Tue Dec 26, 2017 1:46 pm
I use II in my 325 auto box.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Tue Dec 26, 2017 2:11 pm
Topblag wrote:I use II in my 325 auto box.
Good enough for me :D :D
ECP are doing 5 litres for less than £14 with code.
Cheers mate
Post Tue Dec 26, 2017 2:12 pm
It`s the same box I think.......hmmmmmm
darkchild
Post Wed Dec 27, 2017 8:07 am
Yep, it'll be fine. Dexron III has largely replaced Dexron II.
Post Wed Dec 27, 2017 1:23 pm
darkchild wrote:Yep, it'll be fine. Dexron III has largely replaced Dexron II.
I saw a wheeler dealers a while ago and Ed was saying not to put synthetic oil in old box`s and rack`s as the seals can react to this so I plumped for dexron II.
Post Wed Dec 27, 2017 3:56 pm
This the same Ed that crowed about the power increase from fitting a cone filter to an E30?
Total bullsh*te.
Post Thu Dec 28, 2017 6:31 pm
Brianmoooore wrote:This the same Ed that crowed about the power increase from fitting a cone filter to an E30?
Total bullsh*te.
He got that wrong and is still doing it !!
Unless this will totally ruin my box then I will be using it.
What did they use thirty odd years ago then ?
Post Thu Dec 28, 2017 11:34 pm
Dexron II was the original autobox fluid for an E30, along with 20W-50 mineral oil in the engine, and both are fine now, but few would use that spec. of oil in the engine these days if they care anything about the car, and Dexron III is an improved, backwardly compatible upgrade over Dexron II.
