Opening Bosch Alternator
paultv
Post Sat Jun 17, 2017 4:42 pm
OK, so my new bearing has arrived, alternator on the floor, pulley off, 4 long cross headed bolts hold it together - is the only route an impact driver? the threads are seriously in there, and I'm concerned about ripping out the cross heads - if I do, then I'm fooooked.
Any thoughts as a blow torch really doesn't apply in this case.
Paul :-)
Stevieabz
Post Sat Jun 17, 2017 9:58 pm
I tried with a screw driver, once. And proceeded to drill all four of them out and replace the bolts. m5x100mm do the job.
Steve
1987 325i Sport M-Tech 1 - In Absolute Pieces - www.youtube.com/restoreit - For videos on this E30.
1989 325i Touring - Undergoing a much quicker restoration
1985 320i Sedan - Future Project
BMW 1 Series M Coupe - Daily Driver
paultv
Post Sun Jun 18, 2017 6:53 am
That's the way I went, now the bearings? Are they stuck in there or what? Now it's time for some heat!
Paul :-)
Post Sun Jun 18, 2017 10:35 am
Bearings are just an interference fit*. Heat on the alloy casing will help get them out.
*IIRC, this is an alternator that has already been 'rebuilt', so there's the possibility of some bodging juice having been used previously to hold the bearings in.
paultv
Post Sun Jun 18, 2017 11:47 am
Yes Brian, I think this was the case - but they are out, cleaned up and new bearings fit perfectly - I used the well known "SWT" method for extraction.
"SWT"- Swear Word Technology
Paul :-)
