Getting the horn
BMG
Post Thu Mar 02, 2017 12:30 am
Does anyone know which two horns would be correct for a 1990 Euro spec M3 ? There's a multitude of different horns in the ETK and I don't have old parts to get a part number from.
Some have a mounting bracket attached, so guess this may vary depending on model/location ?
Post Thu Mar 02, 2017 8:32 am
well i have these , a pair of oem horns with an oem loom that plugs into the cars single horn loom.
both horns mount to the underside of the flitch panels
http://www.ebay.co.uk/itm/172551354971? ... 1555.l2649
Post Thu Mar 02, 2017 9:59 am
Is that an OE BMW loom then, magpie? All the single/twin horn E30s I've dealt with have had different whole body looms, and, indeed, different bodyshells to suit the number of horns.
Pre facelift loom??
Post Thu Mar 02, 2017 4:04 pm
Brianmoooore wrote:Is that an OE BMW loom then, magpie? All the single/twin horn E30s I've dealt with have had different whole body looms, and, indeed, different bodyshells to suit the number of horns.
Pre facelift loom??
yes it's got a bmw label on it , actually it's the only one i've seen .
It just plugs in at the single horn plug in the middle of the front grills .
i can't remember which year car i removed it from but it's a full BMW twin horn conversion .
Post Thu Mar 02, 2017 6:16 pm
Never too old to learn something new!
Post Thu Mar 02, 2017 6:44 pm
Brianmoooore wrote:Never too old to learn something new!
wow this is a first in my 9yrs on here 8O
BMG
Post Sat Mar 04, 2017 1:19 pm
I have the wiring, just need the correct two horns. They are only 19 -30 Euro each new.
I guess any combo of a low and high tone will work as they seem to all be 510 or 410hz
Post Sat Mar 04, 2017 1:26 pm
BMG wrote: I guess any combo of a low and high tone will work as they seem to all be 510 or 410hz
As long as they have the correct connectors. Single horns usually have two ordinary 1/4" 'lucar' type connectors, while twins have waterproof two pin sockets.
BMG
Post Sat Mar 04, 2017 1:29 pm
Thanks for the info, Brian.
