Bonus/boast
corkie
Post Sat Oct 15, 2016 6:22 pm
My obc has had screen bleed for some time now!while cleaning my garage out today i found a old non working one but the lcd screen was good so i swapped them round and now i have a working obc!chuffed!!
e30
Post Sat Oct 15, 2016 6:28 pm
We all need a little bit of luck now and then winkeye winkeye
Cool
corkie
Post Sat Oct 15, 2016 9:00 pm
Tell me bout it if it wasent for bad luck i wouldnt have any !!
e30
bab-91
Post Sat Oct 15, 2016 10:45 pm
I felt like that when I changed a fuse all by myself!.
Take that Brianmoore!
IG - bab91
Post Sat Oct 15, 2016 11:50 pm
bab-91 wrote:I felt like that when I changed a fuse all by myself!.
But did you work out why it blew?
bab-91
Post Sat Oct 15, 2016 11:56 pm
Yes? :cry:
IG - bab91
steve_k
Post Sun Oct 16, 2016 6:59 am
Yes? :cry:
NO then winkeye
Gert_8
Post Sun Oct 16, 2016 12:51 pm
corkie wrote:My obc has had screen bleed for some time now!while cleaning my garage out today i found a old non working one but the lcd screen was good so i swapped them round and now i have a working obc!chuffed!!
What did you have to do and was it easy?
corkie
Post Sun Oct 16, 2016 6:03 pm
Prety simple i took both apart and swapped the lcd screen!two tags top and bottom seperate the back and front, then undo the screws inside the front bit and the lcd can be removed!if you meed further help let me know!
e30
Captain_Birdseye
Post Sun Oct 16, 2016 7:00 pm
Is Brian Moore a robot?
Gert_8
Post Sun Oct 16, 2016 9:39 pm
corkie wrote:Prety simple i took both apart and swapped the lcd screen!two tags top and bottom seperate the back and front, then undo the screws inside the front bit and the lcd can be removed!if you meed further help let me know!
Thank you. :D
