Can you change the little plastic indicator cancel thing from one wheel to another easily? Looks like just 2 screws?
Any hidden horrors in there?
Steering Wheel slip ring plastic
gausha
Two screws indeed. Make sure to lubricate the slip ring appropriately so it doesn't grind when you turn the wheel!
M3KUK
OK thanks, I've undone the 2 screws but it won't come off. Do you have to push a spring or something in as well?
gausha
I did mine last year, I can't remember exactly, but I recall a bit of careful twisting once the screws are out. It's not difficult, else I wouldn't have been able to do it
M3KUK
Sorted it now it just pulls off, there is a plug for the horn that you pull off.
