Any tips for cleaning carbon out of a head?
ross_jsy
Post Mon May 23, 2016 11:48 pm
Pulling the head off my m30 to replace a broken rocker arm. Might as well clean it all up while I am at it.
Anyone have any tips for cleaning the carbon deposits off? Particularly exhaust ports?
Ross
maggspower
Turbo Farmer Tractor Driver
Post Tue May 24, 2016 8:18 am
Paint thinners is good at breaking down the carbon, don't use brake cleaner. Go at it with a wire brush in a drill, this will get rid of most of the build up. The head will need skimming if you do the chambers.
I soda blast heads it gets rid of all the deposits and is quick. Manually cleaning will take a while.
If you use thinners, do it outside to avoid :mad: :D
ross_jsy
Post Tue May 24, 2016 8:45 am
Cheers will get it soaking.
I always get heads cleaned up with a light skim before putting them back on so may as well do the chambers.
We had a tank with God knows what in it in the garage I used to work in. Leaving a head in over night and a pressure wash would leave it looking like new
