Oil Light On, But Oil Level Fine. 325i Touring....
MPOWERCRAZY
Post Sat Dec 26, 2015 5:23 pm
Hi all,
Recently serviced my car, oil level is fine but the oil light is on, checked the oil level once cold and warm and it's fine. What could this be?
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
jimbom30cab
Tech 1 freak
Post Sat Dec 26, 2015 7:23 pm
I used to have this after disconnecting the battery, it cleared after a few days as oil worked back into the sensor.
BenHar
Post Sat Dec 26, 2015 7:25 pm
Which oil light?
In the clocks or on the overhead display?
Ben
MPOWERCRAZY
Post Sat Dec 26, 2015 7:39 pm
Was on the overhead display, i did disconnect the battery and reset the service light and all is good now, oil level is good too! hope thats the end of the problem :)
BenHar
Post Sat Dec 26, 2015 7:43 pm
Search the zone or look in the wiki.
The oil level sensor gets gummed up and can be cleaned out.
Ben
MPOWERCRAZY
Post Sat Dec 26, 2015 7:51 pm
BenHar wrote:Search the zone or look in the wiki.
Ben
Thanks Mate
Post Sat Dec 26, 2015 8:33 pm
MPOWERCRAZY wrote:i did disconnect the battery
This did absolutely nothing to help towards solving the problem, except provide more time for the oil level inside and outside the sensor to equalise.
The small inlet hole in the sensor is gummed up, and needs to be cleaned by removing the sensor and then repeatedly immersing it in and removing it from a small can of petrol.
andysheep
Post Sat Dec 26, 2015 9:00 pm
Cheers for explaining the proper fix ,as im starting to have this problem.and now i know why it takes a while for the light to go out after toping up the oil,you never stop learning :cool:
Post Sat Dec 26, 2015 9:08 pm
Note that the sensor is designed to be slow responding, otherwise it would be affected by surge.
After refilling a car with stone cold oil, it can take up to about five minutes for the light to go out with one that's working as it should.
MPOWERCRAZY
Post Sat Dec 26, 2015 9:10 pm
thanks, I will look into doing this tomorrow!
Mr-Lachs
Post Sat Dec 26, 2015 9:57 pm
Great to know for the future. The knowledge on the Zone is endless.
Mr-Lachs
1988 BMW E30 325iSE Auto, 4 Door, Lachs Silver (Fair Weather Machine)
2012 Vauxhall Insignia 1.8 Exclusiv, Technical Grey, (The Daily)
