sooo i've supplied full plug and play facelift 1.3 motronic upgrade , my question is does the c101 plug just plug straight in and work ?
i hope so
Do not order, fit or disturb any parts until you have done this.Brianmoooore wrote: Have you checked the condition of the wires in the plug and socket under the inlet manifold, where the injector loom connects to the rest of the engine loom? It's the wires under the lower half's rubber boot that you should be looking at.
Maybe he meant they were on the bench?willnz wrote:He said the earth straps were on... he didn't state where/ whether they were tight/ making contact..
