M20 2.5 with 6 branch, heat shield?
Sambe30
Post Fri Oct 02, 2015 3:29 pm
What can I use as a heat shield on my m20, it has a 6 branch and the ht leads sit above it with no shield[/u]
Ianb
Post Fri Oct 02, 2015 3:50 pm
Have you not used an original E 30 exhaust gasket as that has the shield built in and is fine with a 6 branch.
BenHar
Post Fri Oct 02, 2015 3:51 pm
You should be able to use the standard manifold gaskets which have a built in heat shield.
Ben
Sambe30
Post Fri Oct 02, 2015 4:22 pm
2 of these then? Or do they come as 2 parts ? http://www.eurocarparts.com/mobile/ecp/ ... 786&000462
Sambe30
Post Fri Oct 02, 2015 4:31 pm
Oh sorry should have read it properly :mad: is it just the studs on the manifold I need to remove? No other parts? 10 min job?
reggid
Post Sat Oct 03, 2015 1:07 am
you remove the nuts pull off the manifold, add the gasket then the manifold then do up the nuts
E30 325is with M20B31
