zd3bx
Post
Wed Aug 12, 2015 6:30 pm
Is there any advantage of fitting aero wipers, considering the windscreen of the E30 is not "flat", as it normally is on those cars that come with aero wipers as standard?
The price difference is not huge, but generally has anyone noticed any benefits of aero wipers?
They claim to clean better and cause less noise....Really?
Your thoughts
ross_jsy
Post
Wed Aug 12, 2015 6:55 pm
They don't sit on my windscreen fully.
Worked great on my Impreza though, definitely quieter than the normal ones I replaced
steve_k
Post
Wed Aug 12, 2015 7:53 pm
had them on mine for a while now, no problems at all. only difference is price.
Cypriotgeeza
Post
Wed Aug 12, 2015 9:23 pm
I can 100% recommend them! I have them on both my BMW and My Corsa and I won't go back to normal blades!
The only thing I've noticed is my nearside wiper doesn't contact the whole screen when it's in the park position but it clears the screen as it starts travelling up the screen so it's all good
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Post
Wed Aug 12, 2015 10:38 pm
Aero type simply look wrong, IMO.
jmc330i
Post
Wed Aug 12, 2015 10:56 pm
Yup, same here but it's not a problem. I actually just bought some new 'normal' wiper blades for my touring to replace the aero blades the previous owner fitted - the new blades were shite, so I've refitted the old aero blades!
As Gert says though, they don't suit the E30 at all!
James
'91 325i Sport
'93 318i touring 16v
bigbird76
Post
Thu Aug 13, 2015 8:52 am
Agree they sit too high on the windscreen, Aero wipers do work great but just dont look right on the e30. I fitted a set of Bosch ones to my e30.
Leigh
Post
Thu Aug 13, 2015 9:40 am
aero wipers are fitted to my chariot ......... BOSCH !
+ a yard full of scrap turds
- E30 Zone Meets/Events Team
Post
Thu Aug 13, 2015 6:41 pm
I put normal Bosch wipers on the chromie today, and one with a spoiler
Sanchez
Post
Thu Aug 13, 2015 7:57 pm
I like them practically but they don't suit the e30.
baggimodo
Post
Fri Aug 14, 2015 8:49 pm
Got bosch aeros on mine and agree they look a bit chunky but they work so well I ain't arsed!
Post
Fri Aug 14, 2015 10:24 pm
I fitted some to the track car because they had washer jets built in, and id got a GRP bonnet so had to relocate them. No noticeable improvement over standard Bosch blades I have on the road car
Post
Sun Aug 16, 2015 12:45 am
with bosch aero's and hid's you actually see where your going ... practicality wins .
baggimodo
Post
Sun Aug 16, 2015 8:22 am
magpie wrote:with bosch aero's and hid's you actually see where your going ... practicality wins .
Too true!
zd3bx
Post
Sun Aug 16, 2015 10:23 am
Partly true, except with HIDs you stop others from seeing where they're going...
That's of course unless you have it set up properly at the correct level, which is rarely done.
bosers
Post
Sun Aug 16, 2015 9:36 pm
Can't believe I've read this thread so many times. It has to be, by far, The most boring thing on this forum! a˜ƒa˜Š
reggid
Post
Sun Aug 16, 2015 9:47 pm
Who's got pics of these fancy wipers on their e30?
E30 325is with M20B31
ross_jsy
Post
Sun Aug 16, 2015 10:53 pm
You can see them here:
Gert_8
Post
Wed Aug 19, 2015 6:55 pm
Ha! Peasants require wipers. You lot obviously drive in the wet....
Post
Wed Aug 19, 2015 6:58 pm
Gert_8 wrote:Ha! Peasants require wipers. You lot obviously drive in the wet”¦.
Should be the norm for you being a northern welshie wellie type, or do you wear wellies for the 'other' reason?
Gert_8
Post
Wed Aug 19, 2015 7:09 pm
DanThe wrote:Gert_8 wrote:Ha! Peasants require wipers. You lot obviously drive in the wet”¦.
Only for the other reason.......close to the edge of cliffs.
