Which cooling oil - shocks
tom325sport
Post Wed Jul 08, 2015 12:32 pm
Just ordered some Bilstein B4 shocks front and rear. The back one's were relatively simple to put on but before I start the fronts, the wiki says to use cooling oil in the strut.
What is the best oil to use and how much shall I put in? I've read neat antifreeze can be used?
Post Wed Jul 08, 2015 2:16 pm
I used airline oil, as its quit thin but mainly because it was lying about doing nothing
Post Wed Jul 08, 2015 2:27 pm
DanThe wrote: mainly because it was lying about doing nothing
This is my main criterion as well.
steve_k
Post Wed Jul 08, 2015 2:28 pm
i just used what was in the shed at the time :roll:
tom325sport
Post Wed Jul 08, 2015 2:35 pm
So any 'anti freeze'is OK then?
steve_k
Post Wed Jul 08, 2015 2:40 pm
tom325sport wrote:So any 'anti freeze'is OK then?
anti freeze?? no no no 8O
IIRC i used a bit of left over engine oil when i fitted my koni's.
maggspower
Turbo Farmer Tractor Driver
Post Wed Jul 08, 2015 2:48 pm
I have heard that this is fine also.
The reason it is there is so heat is transfered to the shock casing, rather than there being an insulating air gap.
Personally I use oil though. The grade is unimportant.
steve_k
Post Wed Jul 08, 2015 2:51 pm
i'll be honest, when i was using H&R shocks i did use 3 in 1 oil as it was what i had to hand at the time, had no probs at all.
Demlotcrew
Post Wed Jul 08, 2015 3:00 pm
Problem is that neat anti freeze does not pass the heat through as well as oil, so I would use a good oil instead.
tom325sport
Post Wed Jul 08, 2015 3:29 pm
OK thanks will use some engine oil.
