H&r anti roll bar
heathy325
Post Sat May 30, 2015 8:51 pm
Thinking of getting a rear h&r anti roll bar for the e30 just wanted thoughts on this have anyone else got one? If so how much stiffer do they make the rear
Post Sat May 30, 2015 9:08 pm
Put some proper wheels / tyres on your car. That will make much more difference than thicker roll bars ! :)
kieran325
Post Sat May 30, 2015 9:14 pm
Mines got H&R front and rear, handles well but that might be due to genuine springs and a full make over with oem bushes etc.
heathy325
Post Sat May 30, 2015 9:16 pm
Currently running the standard 15"bbs with toyo proxy tyres got h&r cup kit suspension it's fully polly bushed front and rear but my only trouble is when changing direction at speed like accelerating round a roundabout then Turing left the rear feels very wollowey and not planted so just trying to minimise the rear body roll
400motor
Post Sun May 31, 2015 11:41 am
Moving the front drop link to the strut massively improves body roll for a fraction of the price while also improving the rear
Cypriotgeeza
Post Sun May 31, 2015 12:15 pm
400motor wrote:Moving the front drop link to the strut massively improves body roll for a fraction of the price while also improving the rear
More info on this please winkeye
Check my M30 build threads:
heathy325
Post Sun May 31, 2015 12:21 pm
Ye info please I've never heard this before
zd3bx
Post Sun May 31, 2015 1:22 pm
Possibly just your rear ARB links and bushes are knackered? Also going for 16" with lower profile tyres might help.
Post Sun May 31, 2015 1:29 pm
ala e30 M3's
ross_jsy
Post Sun May 31, 2015 1:57 pm
heathy325 wrote:Ye info please I've never heard this before
I looked into it, have seen people using collars like some coil overs use, although welding a tab onto the strut would be just as easy.
Remember, thicker ARB's reduce grip on the axle they are fitted to, use them for tuning handling balance
bosers
Post Sun May 31, 2015 5:08 pm
I changed my rear subframe bushes, helped a lot with handling. Getting a front strut brace soon, hopefully that'll improve it even more! :)
heathy325
Post Sun May 31, 2015 5:10 pm
All the bushes are new in mine and the suspension is only a month old!! I've got a rear brace cuming so I'll keep people posted in what the difference is
pnd
Post Sun May 31, 2015 5:12 pm
rear bar doesn't do much an uprated front bar will help a lot though.
heathy325
Post Sun May 31, 2015 5:50 pm
It's the rear that's rolling under hard direction change!!
400motor
Post Mon Jun 01, 2015 10:14 pm
Yes as said it's not my idea just copied the m3 setup! I rally an e30 with s50 m3 engine and I have spent 2years developing the handling and suspension, simply moving the anti roll bar links from the lower wishbone standard position to the strut housing directly overhead solved the sloppy body roll front and back, granted I did poly bush all round but after playing round with various suspension setups and spring rates this was the best improvement. Your are basically doubling the rate of the standard one for free.....
