looking to get bbs rm 002
j4gz
Post Sun May 24, 2015 5:20 pm
hi im looking to get some bbs rm 002 15x6.5j et33 i believe these are split rims and originals. From what i can remember can you change dishes and get them wider and will it effect the ET if i change the dishes ?
dooce
Post Sun May 24, 2015 5:55 pm
RMs are 2 piece, and as you mention, the lips can be changed for a wider/narrower version. ET is measured from the centerline of the wheel, so changing the lips to a wider/narrower version will change the overall width of the wheel, thus changing the centerline, which in turn changes the ET.
j4gz
Post Sun May 24, 2015 6:30 pm
dooce wrote:RMs are 2 piece, and as you mention, the lips can be changed for a wider/narrower version. ET is measured from the centerline of the wheel, so changing the lips to a wider/narrower version will change the overall width of the wheel, thus changing the centerline, which in turn changes the ET.
cheers dooce so does that mean that i can go as wide as maybe a 8.5 j rear and 8 j front ?
dooce
Post Sun May 24, 2015 10:14 pm
If I am doing the quick math correctly, you'd need 3" and 3.5" lips to get that width with those wheels and I dont think you'll have the clearance to the wing to run that wide of a lip on an e30
j4gz
Post Sun May 24, 2015 11:56 pm
dooce wrote:If I am doing the quick math correctly, you'd need 3" and 3.5" lips to get that width with those wheels and I dont think you'll have the clearance to the wing to run that wide of a lip on an e30
the et on the wheels im looking at are et33 if that helps .
Post Mon May 25, 2015 12:02 am
No, the original lip is 1/2", so you'll need 2" front lips, and 2 1/2 rears, or you'll need to roll and flare the rear arches.
j4gz
Post Mon May 25, 2015 6:48 pm
sorry for sounding fik so what j will that be then rav on the fronts and back please, and what size tyres u recommend for the fronts n backs pls.
jasso
Post Mon May 25, 2015 8:15 pm
8j and 8.5j personally I would not bother with rm's on a e30 as you will need to drop the car hard to pull a decent look off 16" is the minimum size IMO
