Hi, i have a lot of play in my steering wheel on my 1990 325i sport, when i drive the car the steering is perfect no play when turning its just in the actual steering wheel itself even whens its parked up and turned off i can pull the steering to myself, its like the 22mm nut isnt tight but it is
play in steering wheel
JF008
Have you checked the steering linkage? Be careful!
tomson
Sounds like a screwed column to me if you're certain the 22mm nut is tight with the key in the ignition and the steering lock OFF...
