Ride hight, hight on passangers side to drivers side 30mm
buffalino
Just changed shocks and springs, and there is a difference of 30mm why would this happen , It was the same before i changed the bits, where is this problem coming from?
Jona1971
I had the same problem and it was the rear subframe bushes.
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
buffalino
Thats what i was thinking,! But is that a big job? Do i have to take off the subframe or can i just change the bushings?
appletree
Take it you mean a difference of 30mm between each side? Is so make sure the springs are seated correctly on the pads.
BenHar
Front or rear?
Ben
Ben
buffalino
REAR, and they are seated, 30mm from wheel arch to floor
BenHar
You could try swapping the springs from side to side to see if the difference is caused by the spring length/strength.
Ben
Ben
buffalino
Ben thats the reason why i changed the springs and shocks, i had the problem from b4
BMW_E30vert
Is it a convertible? just a thought the cab had a weight ballast on one side in the rear but i wouldn't think it will cause such a difference when removed
There is a tool which can be used to change the rear subframe bushes without removing subframe
It's not "ballast", it's a harmonic damper - that's why it's mounted on rubber bushes. It removes some of the vibrations caused by a roofless shell's inherent reduced stiffness.BMW_E30vert wrote:Is it a convertible? just a thought the cab had a weight ballast on one side in the rear but i wouldn't think it will cause such a difference when removed
If one rear beam bushes was as bad as to cause such a major difference in ride height, then I'd expect there to be more significant symptoms, such as a significant change of direction when lifting off the accelerator and hitting the brakes.
Measuring the corner weights of the car might be instructive.
buffalino
Do you have a link to BUY this tool,? is it an easy job?
Also i have removed the harmonic damper ! but dont think its that,
BMW_E30vert
There was a zoner who made these cant remember his username maybe try putting a ad in the wanted sectionbuffalino wrote:There is a tool which can be used to change the rear subframe bushes without removing subframe
SiamLars
Previous owner a fatty?!
ross_jsy
Remember that chap who had a facelift arch welded on to his pre-facelift and didn't know why one side was lower than the other? Pure zone gold
buffalino
So i put the harmonic damper back in but no difference! Need some more ideas, ?
Carmo13
I don't mean to patronise, but have you checked the measurements with the car parked in different locations?
Obviously the ground needs to be as level as possible when taking the measurement
Brianmoooore wrote: Measuring the corner weights of the car might be instructive.
buffalino
Its done in the parking and its flat!Carmo13 wrote:I don't mean to patronise, but have you checked the measurements with the car parked in different locations?
buffalino
bump,,,,!!!
Brianmoooore wrote:Brianmoooore wrote: Measuring the corner weights of the car might be instructive.
j2b
Stevey lol, gold indeed.ross_jsy wrote:Remember that chap who had a facelift arch welded on to his pre-facelift and didn't know why one side was lower than the other? Pure zone gold
Not really experienced this yet, x fingers, but what Brian says seems the way forward
Brianmoooore wrote:Brianmoooore wrote:Brianmoooore wrote: Measuring the corner weights of the car might be instructive.
89 more door 6 pot
buffalino
Tell me how and ill have a go ?
