Apart from the obvious 200cc what's the difference between 316 and 318 m40 engines? Is it just the pistons or is there anything else? Are the heads The same?
Reason for asking I'm breaking a 316. I gather there's little call for a 316 engine so wouldn't expect much for it and wondered if I'm better off keeping it fir spares. It has a new sump. Starter, dizzy, alternator are all worth keeping. Spare rocker cover to have a go at polishing or painting. And if heads are the same perhaps one day could have some work done on it.
Ta in advance .,
316 and 318 m40 lump
andyp
- True Old Skooler
there is nothing the same its a complete different engine, if youm have another keep it for spares otherwise its prob bound for china
jmc330i
Eh? The crank is different, but thats about it. Everything else is interchangeable.andyp wrote:there is nothing the same its a complete different engine, if youm have another keep it for spares otherwise its prob bound for china
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
??? Cylinder head, throttle body, manifolds, injectors and all ancillaries are all identical. Only differences are the short engine, AFM and ECU.andyp wrote:there is nothing the same its a complete different engine,
Andyboy
- Alpina Colada
Same block as well.
I think you're confusing M10 316 with M40 316i.
andyp
- True Old Skooler
sorry don't know how but read it as difference to a 6 pot, as we were having a convo here about one at the time
andyp
- True Old Skooler
I thought I could multi task but guess not
eddypeck
Great, that's what I thought thanks for confirming.Brianmoooore wrote:??? Cylinder head, throttle body, manifolds, injectors and all ancillaries are all identical. Only differences are the short engine, AFM and ECU.andyp wrote:there is nothing the same its a complete different engine,
