Another e30 alloy fitting thread
beavis2k4
Post Tue Jan 10, 2006 3:44 pm
would these alloys fit an e30?
http://www.dubmeister.co.uk/wheelinfo.p ... et&style=T
thinking of going 7.5x16 up front and 9x16 on the rear?
I dont have my car lowered at the mo but was wondering how low i could go before i start scrubbing the floor when i have a full load as i am always the designated driver seeing as i dont drink :roll:
beavis2k4
Post Tue Jan 10, 2006 4:22 pm
Do you think they suit? :?
nav786
Post Tue Jan 10, 2006 4:25 pm
yes they will fit with right tyres and correct offset. 7.5 et20 and 9" et15, will work as i run this setup. on 215/40/16 tyres.
FOR SALE
SONY PSP'S £100
e30_nut
Post Tue Jan 10, 2006 4:38 pm
i have a set of those wheels in the same sizes ready to go on my iS when i lower it. The fronts look odd with standard ride height but once the car is lowered they should look good.
Post Tue Jan 10, 2006 6:29 pm
if your a Des i wouldn't lower it at all! or maybe m-tech -20mm springs, or 35mm at a push.
Theres wide wheels and then there is a bit silly and 9j on the back is a bit ott, imo of course. your economy will dip with 9js on the back too
e30_nut
Post Tue Jan 10, 2006 6:39 pm
I was planning on a -35mm max. something like this photoshop i did earlier of a car from e30.de (not sure how low the car in the pic is btw).
Post Tue Jan 10, 2006 6:42 pm
so i'm told if the rim is wider than the arch u will fail the MOT, not 100% sure on this tho
buster
Post Tue Jan 10, 2006 6:51 pm
Simon13 wrote:so i'm told if the rim is wider than the arch u will fail the MOT, not 100% sure on this tho
Yup,thats 100 % true unless you know the MoT tester or just put some other wheels on for the MoT.The plod may still give you some stick though
e30_nut
Post Tue Jan 10, 2006 6:58 pm
They look wider than the arch in the photoshop but they sit in line with the arch when fitted. The rears have a stretch so the arch doesn't foul the tyres.
I've been told about the MOT failure if the rims are wider than the arch but some garages don't seem to make a fuss about it. I know of people that have got the MOT done with the rims about an inch wider than the arch on their veedubs. Strange. :?
Richy325iTouring
Post Tue Jan 10, 2006 7:42 pm
you can get away with about quarter of an inch or so for mot
bmwe30mtech
Post Tue Jan 10, 2006 7:45 pm
Richy325iTouring wrote:you can get away with about quarter of an inch or so for mot
Not legaly you cant, nothing can be outside the arch for rubbing pedestrians etc.
Post Tue Jan 10, 2006 8:13 pm
or hitting kerbs
Cyruz
Post Tue Jan 10, 2006 8:32 pm
These wheels are 'teh sex'. I'm gonna try and find some on ebay.
Johan99
Post Tue Jan 10, 2006 9:08 pm
If you dont want the "german-look" you can have them in a higher ET. The 9x16 ET30 for example...
Johan
BMW 320is-90
beavis2k4
Post Tue Jan 10, 2006 10:40 pm
what is this et stuff? is that how far it sits in the arches? i.e how close it is to the suspension?
ianeire
Post Tue Jan 10, 2006 10:42 pm
Ive 9's on the rear. Car is lowered, dont know exactly by how much as it was think way when I bought it. At a rough guess I'd say 30-35ish on koni shocks... but thats pure guess work. Afaik its running standard Mtec springs and with 3 in the back it rubbed..... badly. Thank god I was going no longer than a few 100 metres.
When the 60/40 cupkit all rearseat passengers can kiss my hairy ass! :o
@Simon: How much do you reckon the economy dips by?
1990 Brilliantred 325i Sport
www.e30owners.com Irish e30
